Old 06-03-2019, 10:43 AM   #1
HeavyHauler
Anyone cut coil springs on 67-72 truck? How much cut and how much drop happened?
I am thinking about cutting front and rear coil springs on my 1968 chevy shortbed fleetside. Has anybody here done this? HOw much did you cut and how much did it drop? Did you notice a big difference in ride quality?
HeavyHauler is offline   Reply With Quote
Old 06-03-2019, 12:06 PM   #2
raggedjim
raggedjim's Avatar
Re: Anyone cut coil springs on 67-72 truck? How much cut and how much drop happened?
One coil from front equals 2-2.5" drop. Rear coils should not be cut (i used to say they couldn't be, but since then I have seen some really sketchy stuff) . As cheap as coils springs are I'd just buy some.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 06-03-2019, 12:18 PM   #3
68 P.O.S.
I wouldn't cut them either. I'd do it correctly from the start.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-03-2019, 12:41 PM   #4
EagleChief
EagleChief's Avatar
That would consist of what? I'm not being a smarta** - I'm trying to learn. Still trying to figure out how to drop my '71.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 06-03-2019, 12:46 PM   #5
7tee
7tee's Avatar
Yep, one full coil equals about 2"...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 06-03-2019, 01:03 PM   #6
cebra
Rear coils can be purchased from a lot of different companies for $100 in any drop amount you want (mostly). To do this effectively over 3" or so, you will need shock relocators and an adjustable panhard bar. 6" and up generally need a c-notch added.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 06-03-2019, 01:14 PM   #7
68 P.O.S.
^^^This. Get new coils of whatever drop you want so you don't mess up the performance of the spring by cutting or heating them.
Old 06-03-2019, 01:58 PM   #8
ga-stepside
ga-stepside's Avatar
One thing I learned about this the hard way. Old springs sag over time. I had 2.5" drop spindles but wanted another inch in the front. I bought 1 inch lowering springs, installed them only to find the front was now an inch higher not a inch lower. I ended up cutting a half coil to get the one inch I was looking for. No change to ride quality. So if you buy new springs make sure what you get will really give you the drop you want.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 06-03-2019, 02:01 PM   #9
demian5
demian5's Avatar
Id be looking at craigslist for some springs first.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-03-2019, 05:20 PM   #10
Ekliptix
Ekliptix's Avatar
I dropped mine 4.5 front and 6 in the rear. You can check out the parts, process and results here: http://67-72chevytrucks.com/vboard/s...d.php?t=612794
I know some people cut springs, but like people said, new drop coils are cheap.
Ekliptix is offline   Reply With Quote
Old 06-04-2019, 02:20 PM   #11
HeavyHauler
Whoa!!! You have a very nice truck. I want to duplicate what you did on my 1968 Chevy C10 shortfleet. Thanks for link to the thread!!!
Old 06-04-2019, 08:47 PM   #12
brownsville
brownsville's Avatar
https://www.youtube.com/watch?v=VHPosx2oStU
this is what i used and it is darn near as precise as you can get helped me out a lot dialing mine in
brownsville is offline   Reply With Quote
Old 06-04-2019, 09:05 PM   #13
Mike C
Mike C's Avatar
That is a good target. But it requires you to convert to disc brakes and use 2 1/2" drop spindles. I highly recommend the disc conversion for a truck you want to drive.
I dropped my 69 4 1/2" in the front and 7" in the rear. I used the conversion disc spindles from Early Classic Enterprises and a 2" drop spring. The rear of my truck is leaf and flipped with a DJM kit.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-05-2019, 04:51 AM   #14
Ganty101
Sweet truck mike c! It just looks right!
Oh and don’t cut your coils guys! Do yourself a favor and buy lowered springs!
Ganty101 is offline   Reply With Quote
