Old 06-04-2019, 12:34 AM   #1
Dodge68charger
Cleaning Engine Block?
I Stripped Down My Engine Block To Bare Metal and Wont Have My Paint Till Next Week.
Just Wondering How I Should Clean and Store The Block Till i Apply The Epoxy Primer? Thanks
Dodge68charger is offline   Reply With Quote
Old 06-04-2019, 08:22 AM   #2
bigmac73
bigmac73's Avatar
Re: Cleaning Engine Block?
clean it with a wire brush and some degreaser, (expect for the cylinders) and then after you give it a good douch/wipe down with solvent spray it down real good with WD 40 to prevent flash rust.
I prefer to use Isopropyl alcohol (90 percent) for my garage solvents, it is cheap and evaporates clean.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-04-2019, 09:43 AM   #3
Minkota
this is very similar to what I do...
https://www.youtube.com/watch?v=t3Rc20Sc8kI
Minkota is offline   Reply With Quote
Old 06-04-2019, 11:48 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Use a Por-15 equivalent and flash rust is no longer an issue...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
