06-05-2019, 05:23 AM | #1 |
Looking into getting 5 stud hubs on the rear!
So currently my 69 c10 has 5studs on the front hubs and 6 on the back. For obvious reasons I’d like to match em all up so either all 5 or all 6. Now I’ve seen some rally style alloys on summit and they are 5-stud which make me lean towards 5 but please guys let me know what my options are. Am I best off getting a conversion kit for the rear drums to put discs in? What info do you need to give me good advice? I know that I have a 411 ratio rear axle option number 4ho4dr.
06-05-2019, 06:30 AM | #2 |
Re: Looking into getting 5 stud hubs on the rear!
you are going to have to swap axles to a 1971 or higher rear end or swap out the whole differential. personally I would call Randy;s Ring and pinion and tell them your issues and let them help you out.
Sounds like some one has already upgraded or changed out the front spindles and brake rotors up front.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
06-05-2019, 06:33 AM | #3 | |
06-05-2019, 06:40 AM | #4 |
you might be able to swap out the axle shafts , like i said call randy's ring and pinon they will be able to help you out. Google them
Do you have disc brakes in the front?
06-05-2019, 06:41 AM | #5 |
Choosing whether to run 5 or 6 lug/stud usually comes down to wheel choice and what pattern they’re available in. Me personally I’ll be converting my 67 to 5 lug when I do brakes over the winter. As far as converting to rear disc, unless you are racing the truck there really isn’t a reason to other than looks.
I don’t know by the option code what rear axle housing you have, 12bolt or HO52. I know with the 12bolt Summit has 5 lug axles available for 67-70 and probably has 5 lug brake drums and the gaskets you’d need for easy shopping. No need for anything special and all stuff most can do themselves, unless you want to change the rear gear ratio which you didn’t mention. Last edited by Overdriven; 06-05-2019 at 06:47 AM. |
06-05-2019, 06:47 AM | #6 |
I do have discs on the front, and I’m guessing there’s a lot more 5 stud wheel options than 6 stud? I dunno about calling Randy’s as I’m in the uk lol. I’ll try a few American car places here though they generally don’t know much about these trucks! I think I’ll stick to drums in the back then to keep cost down as the truck is standard basically.
06-05-2019, 06:49 AM | #7 |
true , discs brakes were available for 71 and up years, so some already did the conversion keep it like it is. I am sure it will drive fine
06-05-2019, 07:35 AM | #8 |
There are multiple 5 lug conversion rear axle kits on ebay with rear axle bearings and drums , Also Summit ,Jegs etc,etc ,Also 6 lug front disc rotors/ bearing kits if you decide to stay 6 lug .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-05-2019, 07:54 AM | #9 |
if its disc in the front, you can get 6lug rotors from summit for the front and call it done, unless you want to run 5 lug for a certain rim choice.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
06-05-2019, 07:54 AM | #10 |
Are the fronts 5-on-5" truck wheels? I ask because some cheapie aftermarket disc brake conversion kits use passenger car rotors with 5-on-4.75" lug pattern.
When I converted my 69 C10's rears to 5-on-5", I simply had a race car machine shop re-drill the stock axle flanges and install new studs. They also turned down the diameter of the wheel locators a little (around .050"?) to allow 73-up wheels to be used. That was done in the mid-1990s, and haven't had any issues. FYI, 71-72 axles are longer than 69 axles, so they won't work in your housing.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
