11-29-2003, 07:20 PM | #1 |
Manifold Install
Ok I have the new performer manifold for my 350 with gaskets and I am about to go install it. Which way is best to remove the carb from the manifold or remove the manifold with the carb on it? The upper radiator hose and distributor are the other things that will need to come out.Is there anything else I am forgetting?
Thanks |
11-29-2003, 07:33 PM | #2 |
TRANS. VAC HOSE..
LINKAGE PCV HOSE MISC. VACUUM HOSE'S POWER BRAKE VAC. HOSE... I WOULD SAY REMOVE THE CARB....PUSH RAGS INTO THE HOLES ON INTAKE TO KEEP FROM DROPPING IN A BOLT THE REMOVE IT..... CAPS...SORRY then clean all surfaces very good....clean....clean....clean.... do not use the rubber seals for the front and rear of the intake... USE SILICONE...... old indian trick...... use a punch,,, and punch little dots across the rear rail and front rail,,of the block and a few on the bottom of the new intake... when the silicone sets...the little punch marks hold ,,,it in place |
11-29-2003, 07:34 PM | #3 |
Pennyless Fool
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
11-29-2003, 08:18 PM | #4 |
Inline 69
torque sequence
youll need a torque wrench,i scanned a pic to show you which order to torque the bolts,i hope its ok, jeff
11-29-2003, 09:13 PM | #5 |
Thanks for the sequence jef5150. I was about to ask about that until I found it in the box. What do I torque it to?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
