06-05-2019, 11:36 PM | #1 |
lots of fans for the 53.
1. 12 volt A/C with remote condenser and drier. I have "Old Air" inside kit.
2. Drag race radiator, front. Goes under the truck. Will be fed with Mazeire 20 GPM electric pump to cool the engine after shut down or as a secondary cooling system if needed. 3. drag radiator rear. 4. Custom 250 amp alternator from Mechman. Large hairpin duel rectifier. 5. Primary radiator, will be fed with high flow mechanical pump. Two 1 1/4" cores with 3300 CFM fan. |
06-06-2019, 04:06 AM | #2 |
Re: lots of fans for the 53.
Wow, that should take care of that blown I-6. Got enough room? I know lots of us are eager for more pics of that beautiful engine.
1951 Chevy Panel Truck |
06-06-2019, 07:18 AM | #3 |
I think it would be very wrong to say "Cool!" Very impressive though. That's a lot of surface area. And a lot of coolant!
Something to consider about the alternator. We use high output alternators in many of our fleet vehicles. In our applications the vehicles tend to discharge while idling and traveling at low speed then the alternator must provide charge as the engine accelerates. Many of the small case, high output alternators available today have lifespans of 12 to 18 months. The electronics simply don't tolerate the heat generated during the high amperage recharge cycles and the alternator is too compact to create the right environment for proper cooling airflow. Some of the European carmakers are actually using water cooled alternators (BMW and Audi come to mind) to increase alternator life. We've used dual rectifier alternators before and they do seem to live longer but if you end up with a problem you might want to consider a way to provide more cooling to the alternator or even changing to a dual alternator system. |
06-06-2019, 09:19 AM | #4 | |
06-06-2019, 09:39 AM | #5 |
I'm polishing the covers and painting the fins now. I'm still waiting on my 12 port alum. crossflow head but it should be cast any day and can go to the machinist so I hope it's not too far off. The A/C is 14" X 14" and drag radiator is 14" X 16". They will go between the frame rails. Still a work in progress. Thank you.
06-06-2019, 01:17 PM | #6 | ||
06-06-2019, 04:48 PM | #7 |
count me as a fan for the 53
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
