Old 06-06-2019, 01:59 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question 1988 R30 Vent Issue
Hey guys picked up a very clean 1988 R30 last week. Been messing with getting AC going, noticed that I am getting a decent air flow from the two inter vents, but absolutely zero flow from the outside dash ventZ. I haven't taken much else apart to check.
Any thoughts to this? The controls will allow me to direct to the floor (heater), but can't get any flow to the outside (near doors) vents.
I am replacing the original DA6 compressor due to a blockage on the low side (which I hear is common with these compressors) with a HR6 which will be here Friday. The accumulator and orifice tube will be replaced too, along with all of rings with a R-134 conversion.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-08-2019, 05:09 AM   #2
Re: 1988 R30 Vent Issue
I have an 88 V30 but I don’t know chit about the vents....but I did graduate from Amador HS
Old 06-08-2019, 05:16 AM   #3
Ford Assassin
Not me, moved here about 3 years ago.
Cable
Old 06-10-2019, 10:03 PM   #4
cdub2010
Check if the venting tubing separated. My glove box was jammed, it turned out to be the flex tubing to the passenger outer vent was separated. I don't think any of the venting was screwed together just press fit.
cdub2010 is offline   Reply With Quote
Old 06-11-2019, 12:56 AM   #5
Ford Assassin
Upon further inspection, there is no ducting going to either end vents.
So looks like I am going junkyard crawling. What years interchange?
Thanks!!
Cable
