Old 11-29-2003, 07:58 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
Question gauges
getting ready to change from dummy lights to gauges i have checked gmcpauls site out and dont see a problem.but on the plug HOW DO YOU GET THEM DA@N WIRES OUT OF THE PLUG.I DIDNT WANT TO PULL TO HARD ON THEM and mess up thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-29-2003, 08:12 PM   #2
gr8scott51
gr8scott51's Avatar
cut 'em
I cut the plug off and used a Painless gauge harness. or did I miss something? Good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-29-2003, 08:27 PM   #3
72shadetree
KEEP ON TRUCKING
im putting the original type in it instead of the dummy lights and you have to change the wires around in the plug so you dont have to put in a new harness
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 11-29-2003, 09:47 PM   #4
john
member #16
john's Avatar
The connectors have a small tang on them, that hold them in the plug.use a small tool to depress the tang then you can pull the wire out. I use a little screwdriver.
john is offline   Reply With Quote
Old 11-30-2003, 01:21 AM   #5
72shadetree
KEEP ON TRUCKING
thanks mine look different than that but ill check it again tommaro i put headlight switch and new heater controls in and by the time i got to the wires i was froze so i probally overlooked it got to get a garage built lol
72 cheyenne 2wd lwb
71 k20 sons
bassett va
