06-08-2019, 11:31 AM | #1 |
Step side bed parts. Crossbars. What goes where?
Bedparts https://imgur.com/a/TecYaj2
Does anybody know the order in which these go on the bed? As you can see I have a step side bed that is assembled partially. In the picture it's upside down and I have the rear cross bar in place but the other 4 I have no idea. It looks like 2 of them are the same and one has the mounting points a little further out and 1 is much smaller. What order do they go in? If anyone has pictures that would be great because I have no idea where they mount or anything. See the link above for pictures |
06-08-2019, 11:38 AM | #2 |
Six in a row makes it go...
Re: Step side bed parts. Crossbars. What goes where?
LMC's catalog has some good assembly pictures in it..
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
06-08-2019, 02:25 PM | #3 |
This is how mine is. Kind of hard to see
06-08-2019, 04:37 PM | #4 |
Is there some kind of rubber body bushing between these strips and the chassis? From the picture it looks like it but I can't find them in the LMC catalog
06-08-2019, 07:09 PM | #5 |
I was wondering this also. I just removed mine and it looked like there was cpvc sandwiched between two thick washers. The washers look stock. The grey cpvc does not haha. I also haven’t seen any in any catalogs where they sell bed hardware kits
06-09-2019, 08:32 AM | #6 |
This might help...it's a long bed though, tailgate is on left. The one cross member that has the pads a little further out is the 3rd one from cab. The spot on the frame is the flat sections out a little further from frame.
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
06-09-2019, 08:36 AM | #7 |
Looking at your pictures ...it seems like your cross member with pads out a little further will go 2nd in from cab.
