DIY4X CrossMember for SBC & BBC
I'm selling my DIY4X X-Member. I had it it for a short time for about 8 months.
Asking $175 plus Shipping
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
![]() Join Date: Nov 2018
Re: DIY4X CrossMember for SBC & BBC
Can you take a measurement between these points, I have a Cummins that I need to know won’t be too wide to fit between the two flanges.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
Just measured mine, if it’s atleast 13” and you can do $200 shipped to 30605 then I’ll take it
It's 11".
![]() Join Date: Jul 2016
What made you decide to not use the crossmember?
Well hell, what about the underside of the flat where the tube meets the flat plate? I could always modify it depending on that measurement.
I'm swapping the SBC for an LS and the diy4x cross member wont work.
Not much more.. About 11.5"
So close. If you get a chance can you get a picture from the front level with the frame. I’m trying to compare to my current engine placement with a 2wd crossmember so I can reference height. If my engine sits high enough then I can use it
![]() Join Date: Mar 2009
$200 shipped?
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
You bet. About to head off to work so I will do this tomorrow morning.
Depends, what is your zip?
Also, Madkidd007 was first to reply so if he ends up passing after I get him the pics tomorrow, you'll be first in line.
#13 |
To a business in NJ 08203
#14 |
Thank you sir. I’ll get a picture of my setup tonight so I can compare tomorrow. My actual oil pan is only 10” wide but the lip and block are 12” so height will be the defining factor
#15 |
Well, I found a couple of pictures online. Unfortunately it doesn’t look like the newer or older style or going to work for me because of the height. Thanks for your time
#16 |
I think that could work. I'll need to take it apart and get a quote from UPS and I wont be able to do that until Wednesday.
#17 |
Sounds good. No rush. Send me your PayPal if it works out.
#18 |
I was quoted $82 to ship. I could do 225 shipped. Let me know. Thanks
#19 |
Wow! That's a lot for shipping. Thanks for sharing shipping with me. I will do $225.
#20 | |
I just pulled it out and will box it up tonight. Will ship tomorrow
#21 |
Paypal sent. Thanks.
