Old 06-10-2019, 10:37 AM   #1
focusedontheprize
focusedontheprize's Avatar
Steel Dually Wheels With Disc Brakes
Hi everyone,
I am at the point on my 1988 Chevrolet V30 Crew Cab dually where I would like to swap the wheels and tires. Currently the truck is running aftermarket 17" wheels with 37" tires. This is my first 4x4 dually so please be gentle on my questions
I really like the look of stock black steel wheels for their simplicity. I have attached a photo of a truck I like the look of however the truck is on stock 16.5-inch dually wheels with 2-inch rear wheel spacers on 36" 36x12.50 Goodyear Military Issue Wranglers.
From the research I have done to date, it seems that people do not recommend going with the 16.5-inch dually wheels due to the limited amount of tire options. My only concern is if I go with a 16-inch wheel, will I run into an issue later when I upgrade the rear 14bolt to disc brakes.
Any recommendations or tips?
focusedontheprize is offline   Reply With Quote
Old 06-11-2019, 08:56 PM   #2
Mike C
Mike C's Avatar
Re: Steel Dually Wheels With Disc Brakes
I have an 86 K30 and I saved that pic years ago. Mine has 16" rims and 235 85 16 Swamper Irok ND's on it right now.
I found a set of 16.5 rims from a motor home that I will run with the Wrangler II military tires. I have a set off my Jimmy from way back. My truck is an off-road only farm truck.
You should have no problems running 16's. I've run steel and the Alcoas that are currently on mine.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-11-2019, 10:30 PM   #3
focusedontheprize
Thanks Mike C. Also sent you a PM.
