Before and After
Specific order installing under hood accessories.
I’m currently rebuilding my 72 with a 67 cab and front clip. All of the front clip is new aftermarket panels, is there any specific order I should follow on installing all the accessories. I mean things like rad, battery tray, horn, wiring and the like?
I didn’t notice anything standing out that needed to be installed first during the disassembly nearly 2 years ago. Help me remember if you have done it more recently than me. Note: I do have the 67 hood latch, rad support, grill support and grill. Maybe more, as I said I have been away from the project for a while. Is there anything else that will need to be specific to this year.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Re: Specific order installing under hood accessories.
There's no specific order that I can remember off the top of my head. It's pretty intuitive from what I recall. You'll need the 67-68 hood if you don't have one already. Nothing else coming to mind
72 C10 lwb fleetside -stock 350/350 combo |
![]() Join Date: Feb 2009
Can't speak for 67, but on a 71-72 the battery box is installed with the inner fender. Best do that before radiator too. Grille before hood.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Looks like you've already got it in based on the pics, but the heater box is way easier if you install it before the passenger's side inner fender.
![]() Join Date: May 2012
The only problem I had was the electrics. I had the change some the connectors, like the head lights. Most everything should go back just like the '72
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
