Old 06-12-2019, 10:25 AM   #1
blazer2007
steering wheel adapter for vette wheel ?
I have a 75 corvette steering wheel that I would like to put in my 80 truck. Was wondering where to get an adapter, Grant was no help at all when I e-mailed them. Are these steering wheels the same as chevelle ?
blazer2007 is offline   Reply With Quote
Old 06-12-2019, 01:35 PM   #2
nlped
nlped's Avatar
Re: steering wheel adapter for vette wheel ?
Yes, it uses the same adapter as all the comfort grip wheels
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-13-2019, 04:45 PM   #3
demian5
demian5's Avatar
On my 70 I needed a 69 camaro adapter to put on a 60 corvette wheel.
But the column on the 73 and up is larger in diameter I believe, you may want to see if you can pull some dimensions from your column and find some for the adapters so you get one that fits clean.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-13-2019, 06:52 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
67-68 Camaro hub works best on 67-72 trucks.
The 69-up Camaro hub is larger diameter and works best with truck that have the ignition switch on the column. (73-87)
Keith
Convert to disc brakes.
Old 02-16-2023, 06:36 PM   #5
G-NUT
G-NUT's Avatar
I know this is an old post but what year steering wheel adapter did you buy to get the outer diameter of the adapter to match that of the steering column?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 02-16-2023, 08:50 PM   #6
lolife99
lolife99's Avatar
What year truck are you putting it on?
Keith
Old 02-23-2023, 10:36 AM   #7
G-NUT
G-NUT's Avatar
I am installing it on a 1984 C10 Suburban.
Old 02-23-2023, 01:20 PM   #8
lolife99
lolife99's Avatar
Since your truck has the larger diameter column (because of the ignition switch in the column) you need the 69-up horn adapter.
Buy one for a 69 Camaro or a 70 chevelle as your application.
Keith
