Champion radiator Thoughts?
So as I'm replacing motor and trans, of course I find the copper and brass radiator starting to leak (who knows how old it is).
I have a non AC truck with a 350/350 combo, should be at about 350 HP. I see the 2-row champions good for up to 500HP, but was going to go with the 3 row just because. I could repair the brass and copper one (4-row) but that could be $400 as opposed to the $250 for the champion. Has anyone had good or bad luck with them? Fitment issues? Trans cooler line fitting problems? It also looks like the lower hose connection is for an AC truck and that is all they sell (as with the coolant return line in the tank for AC trucks). Thanks in advance!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Champion radiator Thoughts?
I bought the CC 369, 3 row...good fit needs rubber bumpers for 4 row. I cut the 1's I had,
left a space in the middle. I have not run it yet, don't forsee any problems.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
I've been running the cc 369 for a couple of years now, it's been a good radiator
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#4 | |
2 years with mine. Fit well. Slight adjustment for top hold down bracket. Cools well! Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
I'm running a Champion 3 row with their dual fan setup on a 69' El Camino with a 396. Only been running a few hundred miles, but so far so good. Fit was good, welds look good, fans work great so far.
For my build I'll be going with RnD to support local, but spending someone else's money, who is on a tighter budget, I would go with Champion again. |
I put one in my 67 c20. I don't remember now if it was 2 or 3 row. I like it, it fit just fine and keeps by stock 327 plenty cool. I have a 4 speed, so I can't comment on the trans line fitment.
I purchased a 3 row cc369 w/dual 14" fans from championcooling/leadfootracing. Ended up not using the radiator due to the fact that I could not use the tranny cooler connections with my existing lines. Was unable to resolve the issue with champion or leadfoot. Sold it to a board member for 100 bucks. The fan shroud and dual fans however fit directly onto my stock 4 row BBC radiator and are working great! Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Trans lines for my El camino project did line up well and were able to connect without much issue. Sounds like it can be hit or miss in that regard potentially.
Moderator
![]() Join Date: May 2007
I have a Champion in two of my three trucks. When the radiator takes a crap in the third truck you can bet I’m using another Champion. Fits well, does it’s job even in triple digit heat with the AC running constantly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Nov 2018
I now own 3 Champions and all fit/hooked up as advertised and still going strong with no issues. My latest was a 4 row in my avatar pic. I bought the 1000 H.P. version from Leadfoot Racing simply because it's a work truck with A/C and I want plenty of cooling reserve. Good people to deal with.
I recommend the whole radiator/fan pkg as a kit.. less the thermostatic fan switch and relay. I have found that almost all of these therm. control switch's supply way too low of a on/off temp range. I have found that a on at 210 off at 185 works best for my application and those temps will be approximate as advertised. This along with a relay can be purchased on Amazon, Speedway, Jegs etc. much cheaper. Important to use the temp sender as a ground to trigger your relay...not ground the fan/fans or it will fail sooner than later because of the fans amp draw. It's also important (to me anyway) to put a fan override toggle in the cab because of slow traffic etc on a hot day. Just my 2 cents worth |
How loud are the electric fans in the combination kit?
Champion here also, good rad and value,
#13 |
#14 |
Good info! You think a 2-row is sufficient in so cal? It seems the 4 row causes fitment issues, but the 3 row is hit and miss.
Anyone painted it black to look kinda stock?
#15 |
I had the same questions. Here is a link to my thread, lots of good info from the guys here:
http://67-72chevytrucks.com/vboard/s...d.php?t=710880 I ended up buying a 4 core champion. I paired it with a dual electric fan setup from Summit. I live in Miami and have been stuck in the summer in bumper to bumper with the a/c on and it never got the least bit hot. https://www.jegs.com/i/Champion-Cool...MC369/10002/-1 Here is a pic. Some MINOR fabrication to get it to fit. After this pic, I painted the brackets and cut off the top of the black mounts and the bolt ends. Looks clean now.
1967 C-10 4-speed, 350v8 Last edited by dave`12; 06-13-2019 at 12:54 PM. |
#16 |
If you want a direct drop in (no monkeying with upper mounts) aluminum radiator, you might look into one of these. Champion makes a good radiator, as I've owned and used a couple. But the factory fit from speedcooling is pretty appealing. I've ordered one for my 67.
https://www.speedcooling.com/1967_19..._Radiator.html
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
#17 |
I have a champion in our 2006 wrangler. It has been great. Works alot better than the factory radiator getting rid of heat.
Very minor fitement issues. Like using longer bolts, extra washers and cutting the corner off the mounting bracket so it would fit. I was suspect of it with the cheap price, but I am pleased. |
#18 | |
Where did you order from? I saw on Amazon for $200 - its from autoradiator KKS369 (thst the one right?) Maybe someone else has used them?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 06-13-2019 at 04:31 PM. |
