11-29-2003, 11:13 PM | #1 |
Broken nipple OT
Here goes again with the 90 olds cutlass 3.1 v6. Heater hose that comes out from under the temp. sensor which is in the manifold under the thermostat. Had a leak in this area. No sign of leak from the sensor, removed it to get to the nipple for the heater hose. Just a light turn with the wrench and I had half a nipple out. The rest is stuck in the manifold, broke off flush. Any ideas on how to get it out without dismantling the top of the engine. Not much room to work. Help please
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
11-29-2003, 11:28 PM | #2 |
Merciless Butcher
They make easy outs for pipe nipples. Try the hardware store. They grip the inside of the pipe nipple. I have had good luck with them.
Your Bought And Sold....I Got Your Soul! |
11-29-2003, 11:32 PM | #3 |
I am a Referee of life.
While you are at it get an 8-point socket to fit the e-z out.it will let you get into a tight spot better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
