Formerly yellow72custom
Rear axle woes
Well, my 12 bolt rear in my '72 C10 started howling pretty bad the other day. I was on the highway, and i noticed a whining noise coming from the rear of the truck. I drove the rest of the way home, parked the truck, and forgot about it. I drove it again, and it was still there. So i topped off the rear axle, and it was about half a quart of gear oil low (leaks through the pinion seal farily bad). It quieted it down a little bit, but the howling is still there.
I am really sure it is the rear axle. If i stick my head out the window, i can clearly hear it coming from the rear of the truck. The noise is there regradless of what speed the truck is going. If i put the truck in neutral and coast, it is still there. If i put the truck in a different gear, the noise has the same tone, although it is hard to hear it over the exhaust. It is also there on all road types (asphalt, concrete, gravel). It seems the worst when i am slowing down, but it is proably because i can then hear it over my loud exhaust. So, any guesses on how long i can keep driving the truck before i need a new rear? This one has at least 200k miles on it, enought to wear out 2 350's and put 30k on another. I know it won't be too big of a deal to change over to a junkyard unit, but i really don't want my rear crapping out on me on a dark night. The truck is my only mode of transportaion, and i use it to drive home from college about every other weekend, so i need to keep driving it until at least Christmas time, when i will have the time to swap in another rear, or look for a cheap econobox to putt me around.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Drive it like U stole it
sounds like the outer pinion bearing is shot . you should be able to have that fixed
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
its all about the +6 inches
Lol longhorn....i do alot of that
![]() ![]() Well, if the outer pinion bearing is shot, about how much would it cost to get that fixed? Since i should be able to find a junkyard rear pretty cheap.....and then i could upgrade to 3.73 gears if i wanted too..... I really don't want to throw very much money into the truck right now. It may just get parked for a while if i can find a cheap econbox beater to putt me around in.....
Registered Cruiser
Lucas.. Are you sure it's not a universal joint?
I intend to live forever. So far, so good. |
If I have anything to say at all, don't ever expect something in the rear end to be an easy fix until it's all apart. My crown and pinion swap ended up being a complete job. The carrier was shot and the spiders were toast, so I put a posi in. Apparently, one wheel burnouts will cause extra wear on the carrier. I'm not sure exactly how it happens, but thats what a couple different journeymen mechanics told me.
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
#7 | |
I have done several hard 1-wheel burnouts, but not too many latley. Proably one 1 or 2 a month....mostly because i dont' want to fry my new tires too bad ![]() Before i got new tires though, i laid 5 or 10 1-wheel marks that were about 50 yards long each.... If it is the rear, i think i will go ahead and put in a 3.73 geared rearend, and just live with it on the highway for a few months until i can find/afford a cheap econobox, and then slowly turn the truck into the hot rod i want it to be...
Well, a little update.
I changed the fluid today (was reccomended by a member on another board). The fluid had lots of little very fine metal particals in it....and was pretty dark. The gearset looked to be in fine condition though. So, i filled it up with 85w140 and called it good. Still howls though. Think i will have any problems putting 80 miles at 60-65mph on it? I'm going home tomorrow evening or on Wendsday.
Its Magically Delicious
i had my rear diff. looked at by a mechanic a few months ago .... he said the gear were in fine shape ... he said there were a couple shims in the wrong place and he added other shims to get it set to zero ... only cost me couple hours of labor ...and no parts .... seems to make alot less noise now.... it could be the case with yours as well ... on the other hand i've never done a burn out either .....
i'd have a professional inspect it ...just to be sure ... being stranded on the side of the road isnt fun
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
I may look into that Mitch...if there is a confident shop in my area that handles rears.....one thing i hate about living in a rual area is stuff like that.
I think the pinon bearing is shot....i can get a new (used) rear for $125...not sure what ratio though....and put it in myself...but it is a pretty big job. I proably should't try to drive it home but i will anyway. I may regret it though...but who knows. I will throw my bike in the back for backup transportation ![]()
good call with bringing your bike along .... i've been told by guys that 12 bolts can go a long long time after they start howling .... if your easy on it (aka no more burn outs or heavy launches) ...im pretty sure it will gte you home alright ... let us know how it goes
Burnouts or heavy launches? Where would you get that idea
#13 |
I got home a few hours ago....the truck made the trip without a hitch. The noise didn't change any....and it feels about the same.
I decided to go ahead and pick up another rear (due to the large amount of fine metal particels that were in my gear oil). Should have one tomorrow or sometime this week. Any tips for putting in the new rear? Looks like a pretty simple job....i will go ahead and rebuild the brakes on the new rear too. I think i will get one with 3.07 gears, even as much as i want 3.73's. I drive the truck on the highway 90% of the time....so i need to be pretty smart about my gear selection. It dosen't look like an OD tranny or a econobox will be in my budget anytime soon also. Oh well ![]()
#14 |
Young Gun wth Fast Inline
I ve loooked for a 3.07 rear for a while. I finailly gave up and now have a lead on a cast overdrive tranny
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
#15 |
im glad you didnt have to use your bike ..... i stopped riding mine for fun a few months ago ....let use know how the rear shoppin goes ....peace
#16 |
I've done the bike thing a lot.... sucks. Specially when its winter and nobody expects some idiot to be on a bike in the middle of a snowy night. I got tired of wipping out on ice patches.... so now I have 3 trucks.
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
#17 |
MOVE OVER
Mine is/was doing the same thing, it is probably the pinion bearing as it did leak around the front seal and one long trip, it got real hot and almost locked up.. finally got a parts truck from teeitup and now swapping rears for it.. I think short trips are OK as long as you keep adding fluid,, but of course it also leaks out.. if you can wait a little bit.. till I get mine back on the road,, I live in KC, but travel to your area usually bi-weekly to work my Dad's farm.. (he's getting older) maybe you can check with teeitup and see what he has in rear ends.. and I'll pick it up for gas money,, either meet you at st. robert,, or maybe even have my brother (he lives in Rolla) drop it off there...
No matter where you are..... There you are... Buckaroo Banzi |
#18 |
Thanks alot for the offer Rambler, but i was lucky enough to find one today
![]() I go back to Rolla for college around the 10th of January....let me know next time you are town and maybe we can meet up and talk trucks for awhile ![]()
#19 |
MOVE OVER
No Problem, glad you found one.. Your around my old stomping grounds.. My folks actually live in Plato,, if you know where that is,, Houston MO , was the big "city" to me back then.... I'll give you a yell around then,, and we can definelty talk trucks,,, talk my brother in dumping his S-10 for a real 67-72!
#20 |
Yeah, i know where Plato is....population 74 i think. Right on the headwaters of the Roubidox (sp?) creek. I spent alot of time in Texas county putting up gypsy moth traps the summer before last for my job. Had alot of fun too.
Willow Springs is my home....and Rolla has become my other home now, lol. Hope to see ya around sometime ![]()
#21 |
what rear did you end up getting? what gears and all
'67 c10 350/th350 |
#22 |
Highboy, today i drug home another 3.07 geared 12-bolt without posi. As much as i hate 3.07 gears, i drive the truck on the highway almost all the time and i need the extra gas mileage.
I already started cleaning it up....tommorow moring i will give it a fresh coat of gloss black paint and start pulling out the old one....maybe i can get it done in one day ![]() ![]()
#23 |
no posi, that sucks. atleast you found a new one. hope all goes well.
'67 c10 350/th350 |
#24 |
After reading this I should be concerned!! I've been driving my howling rear end for about 6 months nonstop everyday!!!! Heck, I just drove it from Cali to Texas at 80-85 MPH the whole way. I had no idea they would lock up because of this!! I guess I should quit doing burnouts ( I average about 2 a week). Of course ignorance is bliss, and now that I know about this my rear will go out
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
