Drum brake backing plate
Hi all, found my rear drum backing plate has groves/gouges where the shoes ride. Do I need to replace the backing plates?
Thanks for any help.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
Re: Drum brake backing plate
Unless it is rotted or beaten beyond use, I would re-use it. New shoes, new wheel cylinders, and new springs are all that is needed in most drum rebuilds. If you can, you should post a picture, so we can give you a better judgement.
Decided to go rear disc
| Bookmarks |
