Almost Satisfied
![]() Join Date: Mar 2002
How do the rubber cab mounts go?
Lost Wages gave me a set of radiator support and cab mounts (rubber) but I can't figure out what goes where.
I have the radiator support figured out I believe. It uses a smaller diameter rubber and has flat rubber (rather than coned) pieces for the bottom. On the cab I have two different thickness rubber pads. Do the thicker ones go in the front or the back of the cab? All four have the coned pieces for the bottoms. I would like to set the cab back on the frame tomorrow, but I need to know how these go first. Any help would be greatly appreciated.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Robert Olson Transport
![]() Join Date: Oct 2002
if ya have a LMC book it shows ya in the pic how they go
Almost Satisfied
I do have the LMC book, but it doesn't show which end the thicker rubber pads go on. Front or back? Their pic makes it look like both are the same.
here u go
another
Almost Satisfied
for taking the time to post that pic for me. I think that pic is for the C-20's if I'm not mistaken.
Here is what I have....
Have A Nice Day!
Those pictures posted of how they go together were for the 3/4 ton and 4x4 mounts. I just put a set on my 4x4. If you look at the LMC catalog for the 1/2 tons it shows the thicker mounts in the rear. Hope this helps
Are those poly mounts?
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() Last edited by 70 CST 4X4; 11-30-2003 at 12:40 AM. |
1/2 toners
Are there any torque specs with those or do you just reef on them til' you can't reef no mo? Just wondering because I got lots of different advice in that area.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
Have A Nice Day!
30 ft lbs. This was in the assembly manual. Should bottom out then go around 30 ft. lbs.
** use some anti seize on the threads**
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() Last edited by 70 CST 4X4; 11-30-2003 at 02:45 AM. |
Hey Mark, thanks for the pic of the C20/K10-20 rubber. I have a cab mount set that I bought for the 4X4, but decided to sell it and restore the 9 foot step. Now I know they can be used on the C-30 as well.
Almost Satisfied
Just FYI. The thicker ones went in the front.
