06-14-2019, 05:41 PM | #1 |
6 lug disc to 5 lug disc conversion What wheel ??
Previous owner did a 6 lug disc conversion a few years ago.
I'm about to convert the 6 lug rotors to to 5 lug rotors. I'm in a pinch and I need to find (2) 5 x 5 front wheels. I can't find any 5 lug c-10 wheels locally, can I just pick up 2 later model wheels that will fit, (what year) ?? until I convert the rear to 5 lug, and buy a nice set of wheels & tires next year. |
06-14-2019, 06:04 PM | #2 |
Re: 6 lug disc to 5 lug disc conversion What wheel ??
Will these work in the front, they are from Summit ??
Steel wheel, 15 in. x 7 in. 5 x 5 in. Bolt Circle, 4.25 in. Backspace Offset: +6.00mm Center Bore Diameter (in): 3.217 in. Center Bore Diameter (mm): 81.70mm Last edited by kens65fb; 06-14-2019 at 06:13 PM. |
06-14-2019, 08:48 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
As long as they are 5on5 or 5 on 127
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-14-2019, 09:28 PM | #4 |
Moderator
If you want dirt cheap, and readily available, all full size Cadillac 1996 down are 5x5. So are all 91-96 B bodies (Caprice/Roadmaster/Custom Cruiser/Impala SS). So are all B body wagons from 77-up. So are all 71-76 GM full size. So are 5 lug GM pickups. So are 5 lug Astro and Safari. And... mid 70s Ford full size. And probably more that I am forgetting.
06-14-2019, 09:33 PM | #5 |
try looking at www.car-part.com
