K10 frame
I have a bent K10 frame and have not been able to locate another one. Is a C10 frame similar where I just need to mount the front spring hangers ?
![]() Join Date: Apr 2006
Re: K10 frame
Pretty sure they are the same other than the suspension.
Kirk 72 Blazer CST 4wd highlander |
![]() Join Date: Oct 2013
Re: K10 frame
Not sure this helps, but for 64 to 66 K10 trucks, they used the one ton frame. Do not know, if this carried over to 67 to 72,
A good source of information that will have answer is the “ GM Heritage Center” you will have to search a little to get to the year specific truck information. Maybe a search here on GM........., will provide an detailed route of how to get to year specific truck information. Les |
![]() Join Date: Nov 2018
Re: K10 frame
The 67-72 4wd frame uses the 1ton rear leaf spring spacing, but not the 1ton frame. A leaf spring 2wd frame is what you’d want if you’re going to be converting a frame. The trailing arm trucks rear frame dimensions do not lend themselves to a leaf spring conversioN. I have a 1 ton leaf frame in the yard with the 4wd spring hangers put on to convert it.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
| Bookmarks |
