Old 06-15-2019, 12:43 PM   #1
Blazerowner
Blazerowner's Avatar
Dana 44 oil capacity
So I installed a TA performance diff cover and am wondering about the oil level. Per their instructions I filled it until it slightly ran out of the fill hole on the cover. I seem to have a small leak from the yoke. Very slight, just a few drops. I don’t know if the fill hole is the same height as stock and it took about 2 1/2 quarts. Per them it has 1/2 quart extra capacity. What do you all think? Is it too full? Why would I have a slight leak in the yoke. This a rebuilt unit by a reputable shop. Is it normal to have this leak a little when the seals are new?
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-15-2019, 01:44 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Dana 44 oil capacity
NO...leaks are not normal... my stock cover held about 1/2 gallon...they could have damaged the seal upon install..keep a eye on it for a few days..if it still leaks.I'd take it back to them...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-15-2019, 03:17 PM   #3
Blazerowner
Well I’m in the middle of the build so it will be a while to even have it running to get it to them. That sucks I may call them and see what they say. Is the seal easily replaceable? I have the tools to replace a seal I just don’t know much about the pinion and if it needs to be torqued properly after removal.
Kirk
Old 06-15-2019, 04:49 PM   #4
mongocanfly
Post Whore
Depends on if the usd a crush sleeve eliminator or a crush sleeve....you might try rotating it some and see what happens...it could have some trash under the lip as well...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-15-2019, 06:52 PM   #5
Blazerowner
I’ll try that. Can I remove it and use a crush sleeve eliminator or a new crush sleeve? I have a torque wrench as well. I think I could do the work if needed.
Is the fill hole fine where I filled it to? Not too high?
Kirk
Old 06-15-2019, 11:06 PM   #6
mongocanfly
Post Whore
if you change to a crush sleeve eliminator the pinion rotational torque will need to be reset..pretty much means the diff would need to be tore down....since its the front diff and not used as much as the rear I think id just leave the crush sleeve alone if that's what they put in there...ive changed seals before and just retorqued the pinion nut and got by with it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-16-2019, 02:19 AM   #7
Blazerowner
I’m hoping to get it up on jacks and spin it to see if there is something causing the leak. I did clean it up and repaint after the rebuild maybe some gunk got in there. I don’t know a lot about the differential. It’s annoying since I paid about $1500 to have it rebuilt and this is happening. I’ll have to look at my invoice to see if there is a crush sleeve on it.
Kirk
Old 06-16-2019, 07:18 PM   #8
Blazerowner
So I looked closer and it wasn’t leaking from the differential. It must have been from the filler tube when I cleaned up and I just didn’t happen to notice it. I feel much better about that. Any opinions on the fill level? Is to the fill hole fine?
Kirk
Old 06-17-2019, 12:52 AM   #9
mongocanfly
Post Whore
that's where its supposed to be ...bottom of the fill hole
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-17-2019, 10:06 PM   #10
Blazerowner
Awesome. Thanks for the info.
Kirk
