06-16-2019, 11:30 AM | #1 |
Bed wood stain question
I planed my barn wood bed wood and deciding on a stain for it. I found a stain I like but it's a indoor stain so looking to use this and then coating it with something for the outside to protect it. What are your suggestions? Can I even use this?
06-16-2019, 01:23 PM | #2 |
Re: Bed wood stain question
never built a truck bed but I build cornhole boards on the side for people and I a similar stain for them and coat them in a UV protectant polycrylic and they hold up fine. Granted, a truck bed will see more wear/weather so there may be a specific finishing protectant geared towards truckbeds possibly a marine finish.
06-16-2019, 02:01 PM | #3 |
Use a marine grade clear varnish or u will be doing it again in just a couple yrs. I use Epifanes high gloss clear varnish. Only place i found it was on line. Buy two qts. Expensive but worth it imo.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
06-16-2019, 02:03 PM | #4 |
You might get away with less if you have a bed tonneau cover.
06-16-2019, 03:23 PM | #5 |
