Old 06-16-2019, 02:56 PM   #1
SilveradoDude
Question Fuel pump pushrod won't budge
(85 C10 305)
I pulled my old fuel pump cleaned and prepared everything. I tried using needle-nose pliers and thin screwdriver to try and pry the pushrod up but it is not budging. What do you think is going on here?
Should I attempt to take that pushrod plate off to try to get to it?
SilveradoDude is offline   Reply With Quote
Old 06-16-2019, 03:50 PM   #2
kidatheart
kidatheart's Avatar
Re: Fuel pump pushrod won't budge
I use a hacksaw blade to get under the end of the rod to get it started up. I have never had any luck with needle nose pliers on the rod.
kidatheart is offline   Reply With Quote
Old 06-16-2019, 04:12 PM   #3
sweetk30
sweetk30's Avatar
they are tricky for sure at the angle there at in a tight hole with oil on them .
also lots of people dont know you can pull the bolt from the front face of the engine in the area of the pushrod tube and install a longer bolt to hold it up in place as you get the new pump installed . then remove the long bolt and reinstall the short bolt .
good write up http://www.crankshaftcoalition.com/w...k_Chevy_engine
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-16-2019, 09:08 PM   #4
cadillac_al
Oh yeah, fun times getting that rod up. I usually start trying to twist it with my index finger. If I get it to turn a little it will usually start moving up. Then I use the long bolt trick to hold it up.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-16-2019, 11:29 PM   #5
fordguy40
Thanks for the heads-up on the long bolt trick. I ended up using thick transmission assembly grease to hold the pushrod up when I replaced the pump, but I'll be sure to keep that bolt in the truck's emergency stash of assorted tools and fluids.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 06-17-2019, 09:47 AM   #6
JMac11
JMac11's Avatar
Many oil leaks have been misdiagnosed because of that missing bolt or no sealant on the short bolt.
JMac11 is offline   Reply With Quote
Old 06-17-2019, 11:00 PM   #7
Redneck Rydes
Redneck Rydes's Avatar
X2 on the hacksaw blade
Redneck Rydes is offline   Reply With Quote
Old 06-18-2019, 10:17 AM   #8
KShortell
KShortell's Avatar
Neat idea on the longer bolt. I had a real bear of a time on the fuel pump twenty years ago on the '86 Suburban I used to have. Only later did I learn of the old trick of using grease to hold up the rod while installing the pump. That would've definitely helped on my 350.
Semper Paratus
KShortell is offline   Reply With Quote
Old 08-29-2019, 01:50 PM   #9
SilveradoDude
Question Re: Fuel pump pushrod won't budge
Hacksaw blades don't bend...they break.
Old 08-29-2019, 01:52 PM   #10
SilveradoDude
Exclamation Re: Fuel pump pushrod won't budge
I can not budge it with my finger that's the thing it feels like it is stuck it doesn't move at all, what about removing that bottom cover plate to get to it? I really need some help here.
Old 08-29-2019, 02:28 PM   #11
geezer#99
geezer#99's Avatar
I’ve used long nose needle nose pliers before.
Gripped it, lifted it and slid a hacksaw blade in so it wouldn’t get stuck down again.
Old 08-29-2019, 02:52 PM   #12
MJN
MJN's Avatar
Won't hurt anything to take that cover off, the push rod is most likely resting against it anyway.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-29-2019, 07:10 PM   #13
kidatheart
kidatheart's Avatar
I guess that is good information for something....
Old 08-29-2019, 08:01 PM   #14
SilveradoDude
Ok, I took the bolts off the cover and somehow that loosed the pin from it's resting position, from there I was able to scoot a bent hacksaw blade in there and push it out of the way.
A couple of points:
- Hacksaw blades are not automatically bendable. You need to look for the ones that are marked flexible and even then I would heat them before bending.
- Not everyone's small block has the holes for the long bolt trick, I know mine doesn't
- That mine coupled with the awkward position of the mounting bolts makes for a job that should be a snap into a very difficult job. Whoever designed that crap needs to go back to engineering school.
Old 08-30-2019, 10:19 AM   #15
hatzie
Moderator
hatzie's Avatar
I learned that one about 20 years ago. Wish I'd heard about it 20 years before that...
Around 1981 or 82 the 350 in Dad's 1978 G20 van needed a fuel pump. I had a devil of a time with the pushrod.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
