will these work in our trucks?
i stumbled across this on ebay and wondered if they would work in the tail lights of our trucks?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2445544286
he who dies with the most toys wins... |
autozone sell's them....but it there if it works.....let us know
ive heard autozone and walmart sells them but have never found them....just wondered if they had the 30 leds these have....thought about getting one for my vstar1100 anyway and seeing what it will do in my 69
I think they will work since they just plug in to the socket. The problem with these is the light is intence around the lights themselves. Longhorn Man has worked out LED lights that will fill up the entire fleetside red lenz area. I think it has about 85 LED bulbs.
#5 | |
Martin Gibson
USAF Retired 1964(-ish) C10 |
![]() Join Date: Nov 2003
I use them on my bike and they work great.
its all about the +6 inches
They pretty much blow though. I've seen them on a guys car at work. The light is aimed almost like a flash light would do...kinda like a spot light and not a flood light.
Old member
Yea they are bright,
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
It was mentioned in a post a while back about these LED lights that the ground has to be good for the lights to work right. The current draw is so low that it needs a good ground.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I also had a set and could never get them to work for very long,but when they did work they were like a flashlight like longhorn man said..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
