![]() Join Date: Aug 2018
When to replace Dana 44 bearings?
I've got a Dana 44 rear axle and I'm wondering if I should replace wheel bearings and seals. The truck has 35,000 miles on it and I'm pretty sure they've never been changed. Are there any indicators I can look for without taking it apart to determine if they need to be changed? Or due to age is it a necessary task?
I don't know a lot about axles, but from the research I've done I'll have to pull a drum off and take out the bolts behind the hub and pull the axle out and then carefully destroy the race and the bearing to remove them and then press on the new.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Who Changed This?
![]() Join Date: Jan 2013
Re: When to replace Dana 44 bearings?
The bearing presses onto the axle shaft? If it ain't leaking grease or rumbling, I'd just drive it.
Only 35,000 miles on the truck? They should be fine. Most last the life of the vehicle... unless lube got low due to a leaky seal
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-18-2019 at 09:45 AM. |
I didn't take note of how much oil was in the diff, but quite a bit came out. I will be pulling the drums off to rebuild the brakes, I'll look for leaks when I do that and see if there are any apparent issues.
Thanks for the feedback everyone.
Always good to remove, clean, and inspect. If you can't remove w.o destroying then I guess you'll be replacing them. If you do, try to get Timken brand.
