engine size emblems below front side marker lens, what is correct?
Looking around at pictures all over the internet, I'm seeing some trucks with the "8-350" emblems for instance, under the front side marker. But most pictures I see, the truck does not have these. And I can't find any rhyme or reason (year, trim level, engine type etc) as to why these truck have or don't have the emblem. What is correct? with or without? I have a 70 c10 short stepside that has a 350 in it now. It originally was a 6 cyl I think. It does not have the holes in the fender for these emblems. But I found some new emblems at the swap meet and I'm not sure if I wanna use them or not.
![]() Join Date: Jul 2016
Re: engine size emblems below front side marker lens, what is correct?
If it came with an optional engine such as 292, 350 or 396/400 it got the corresponding emblem.
so... EVERYTHING except the base engine got an engine displacement emblem on the front fender? and also, what determined whether the emblem was placed under the side marker or on the fender behind the front wheel?
I have a radical idea!
Correct - only optional engines had badges. Location was determined by year. Under the emblem for 69-70 and under the marker light for 71-72.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Roadtrip!
![]() Join Date: Feb 2003
This is correct...On a side note, Gmc didn't have an emblem for engine size. And for more confusion, I think 68-70 4x4s had a 4 wheel drive emblem under the front marker light.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Agreed. I have a GMC now and a previous 67 and the GMC never had an engine emblem. Does not mean a guy cant add one if they wish. I left mine without the badging. I did add all the other optional outside trim though.
Roadtrip!
67-68 didn't get engine badges. The c-40 and up may have had 366 or 427 on the side of the hood.
My '69 C10 short step spid doesn't say which engine and there are no engine size badges on it. Original paint truck. It does callout a 3 speed automatic. The guy I bought it from said it didn't have an engine when he bought it but the previous owner said it was a 307 turbo 400. It has an original V8 wiring harness. So was the 307 considered a standard V8 if you ordered a V8 truck?
'69 swb stepside in progress. '59 Corvette lifetime project |
![]() Join Date: Oct 2009
Yes, if your VIN starts CE or CCE, as opposed to CS or CCS and there is no engine option on the SPID, it was born with a 307.
#11 | |
Tom
At the body shop.
Our 68 begin with with CE and has a 327 in the spid or is the CE vin for 69 and up?
" That didnt make it any newer " " Dont antique the equipment " |
#13 |
![]() Join Date: Feb 2009
How you guys keep all this info. straight in your head is beyond me......Simple trucks, yet so many variables.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#14 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Yes, and we seem are always finding out new things about the trucks. Reminds me of an old saying " When you think you have all the answers its because you haven't heard all the questions". There are pretty much no absolutes with these trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#15 |
True story. Top of my head there's a half dozen "is", "because" and "must be". None are true.
#16 |
CE (E = eight) means V8 for all our years; CS (S = six) means 6 cylinder.
Base V8 in '67 = 283; base V8 '68 - '70 (at least, I think through '72) = 307 A '68 with a 327 should have a code on the SPID.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#17 |
At the body shop.
I mis read it. Unless it's called out it's born with a 307
