![]() Join Date: Jun 2009
Speedometer correction - Saginaw 4 speed
I was out today doing some math to find my transmission gear ratios. I have a 71 stepside 350 with saginaw 4 speed. 3.73 gears 295/50/r15 (26.6") rears. I am trying to correct the speedometer and am not sure how to go about it. I have tried to search but cannot make sense of it.
Turns out it is a "2-line" saginaw 4 speed with gear ratios as follows: 1 - 3.11 2 - 2.20 3 - 1.47 4 - 1 My speedo compared to GPS is 1.3 too fast. For example: Speedo says 13, GPS 10 Speedo 39, GPS 30 Speedo 65, GPS 50 Speedo 95, GPS 70 How do I go about correcting this? |
Who Changed This?
![]() Join Date: Jan 2013
Re: Speedometer correction - Saginaw 4 speed
You can buy an adapter.
One example, but just a web pick, not a recommendation for them in particular. https://transmissioncenter.net/produ...dometer-gears/
thanks, looks like I need to determine which I have in there now and get one with less teeth.
How do you remove the speedo gear? |
Who Changed This?
You can just bolt the adapter onto the transmission where the speedo cable goes, then attach the speedo cable to the adapter. But if you want to try a different driven gear, there is a 1/4"-20 (I think) bolt with a tab that keys into the part that is on the trans now and holds the driven gear. Take a look, you will see it. You can only go up or down so much on the driven gear, as it is matched to the drive gear on the output shaft. It's a big enough pain to change all that that the factory has adapters they just pop on to get them close enough.
Like this? I don’t know if this one works for saginaws but is this what you are talking about? I think the slow down 26.7% would get me close
https://transmissioncenter.net/shop/...ratio-adapter/ |
Who Changed This?
Yeah, but it's a shame that they cost so much. The company can steer you to the one with the right size threads.
Ditto on the addition of an adapter.
That 3.11 low gear Saginaw is a nice trans btw. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#8 | |
I don’t mind the transmission. It’s no Muncie but it serves its purpose. I like the ratios. Quick off the line. I avoid super hard shifts cuz I know it’s not the strongest thing in the world |
Who Changed This?
I had a 4-speed Saginaw in my '69 Camaro. A hard start or two and something went wrong with it. I had it out and apart a couple of times but couldn't figure it out. That was in '72, and I wasn't all that much of a transmission guy. It would clatter while in gear on hard acceleration, but was OK in 4th. I drove it like that all the way to Illinois from California for my US Navy "A" school, and bought a Muncie 4-speed and put that in while I was at school there.
#10 | |
Who Changed This?
No, sadly, I parted ways with that Camaro in '75. 327 and a 4-speed RS with a tach and gauges. If we only knew, right?
