11-30-2003, 04:31 AM | #1 |
Shaved door handle ??? # 2.
I appreciate all the help with the last question about the solenoids for the shaved door kit. One more. Do any of you have pics of the solenoids installed? I'm not sure where to install them in the door. Thanks!
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! |
11-30-2003, 03:16 PM | #2 |
www.73-87chevytrucks.com
Cochino has pics posted here:
http://67-72chevytrucks.com/vboard/s...shaved+handles
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-30-2003, 08:08 PM | #3 |
I saw that thread, but I can't really figure it out. What I need is a pic that shows the bracket installed. I don't know where to mount it in the door. Thanks though!
12-01-2003, 09:38 PM | #4 |
ttt
12-02-2003, 02:06 AM | #5 |
I doubt it will mount inside the door skin. It has brackets that hold the solenoid in place, and the bracket has to be bolted in. Here's a couple of pics of the solenoid set up. The first one shows the solenoid, bolts and mounting brackets. The 2nd pic shows the bracket mounted to the solenoid. The solenoid pulls into the body of itself. I really need help here! Lol.
12-02-2003, 02:07 AM | #6 |
Pic # 2 - solenoid and bracket assembled.
12-02-2003, 01:18 PM | #7 |
It followed me home?
does that kit use a cable? or does it use a rod, like a door lock actuator? If it uses a cable just pull the latch in the door so you know which direction it needs to be pulled. Then just mount that bracket in a straight line from that point.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-02-2003, 01:34 PM | #8 |
BeWarE tHe eViL CrAnkTOe!
I posted pix of this once before....dont know if its still here though?
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
12-02-2003, 07:22 PM | #9 |
Cochino - yeah, it uses a cable to pull the rod.
Riptide, I know you're trying to be clear, lol. I really appreciate this guys! Thanks a lot!
