06-18-2019, 02:56 AM | #1 |
Bed mounts - is this correct?
1971 Chevy stepside SWB. I removed all the rotten wood. I see the 2 bed cross sills closest to the can have what look like CPVC looking spacers between the sill and frame mount. Is this correct? Doesn’t seem like it. I don’t see anything in LMC that mentions them. Bed is level, body lines appear to match up. Are they supposed to be there?
06-18-2019, 02:57 AM | #2 |
Re: Bed mounts - is this correct?
Sorry last 2 mount pics are upside down
06-18-2019, 08:44 AM | #3 |
No that is not right. That looks like a homemade body lift. Bed should at the most have thin rubber pads. Some were metal to metal.
06-18-2019, 09:23 AM | #4 |
No, that's not right. I have new pads to replace mine and there rubber, about 2" square and not much over 1/4 or so thick.
06-18-2019, 09:59 AM | #5 | |
What do the cab mount bushings look like? Would seem with that much of a spacer in the bed they must have lifted the cab too.
06-18-2019, 10:02 AM | #6 |
Mine prior to removal
06-18-2019, 10:54 AM | #7 |
Hmmm. And it’s just the two forward most sills. The others are metal on metal. Seems like that would make it angled. But the gap between the cab and bed it even. I’m so confused
06-18-2019, 10:56 AM | #8 |
06-18-2019, 11:05 AM | #9 | |
Wonder if those sills are incorrect and not tall enough. |
06-18-2019, 11:23 AM | #10 |
I guess it’s possible the rear sills are too tall or the fronts are too short. Do these look like they are in the correct place?
Any idea where I can get height dimensions of the different sills? |
06-18-2019, 03:35 PM | #11 |
Best I got . Hopefully you can zoom in on it. But no shims
06-18-2019, 05:17 PM | #12 |
I think the front of your bed is too high. Probably not as high as those PVC would indicate though, looks like maybe only 1/4-1/2".
You also have spacers to make up for the bed wood missing... are those the same width as a bedwood board? Are you sure the cab mounts are right?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 06-18-2019 at 05:27 PM. |
06-18-2019, 05:26 PM | #13 |
Your frame mounts look correct. My truck is a verified factory shortbed stepside.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-18-2019, 05:30 PM | #14 |
It does look like it. The gap between the bed and cab is pretty even. The top of the bed front and rear is both 41”. The pvc looking spacer are at least and inch or inch and a half. The bed wood spacers are 3/4” just to not pinch the gap.
I’m hoping to see some shortbed sills both for sizes and placement. Mine could be incorrect. Or placed wrong. It’s an original SWB not cut. But lots of donor trucks make it up I am finding. |
06-18-2019, 05:32 PM | #15 |
That’s a great picture thank you! I’m glad that is correct. Maybe my sills are incorrect. Are they all different or are some the same/interchangeable? A couple of mine look similar but some bolts are in inside holes and some are in the outside holes
06-18-2019, 06:12 PM | #16 |
I'll take a peek under mine when I get home. My dad and I did the bedwood in like 1998, so it's been a minute
06-18-2019, 08:09 PM | #17 |
My front two mounts were both +/-2-1/4" high so I think you have the right ones.
06-18-2019, 08:50 PM | #18 |
I attached a couple more pics. Cab mounts are pretty toasted. That’s what I was looking into. Then I found the ones in the bed and was looking for those but didn’t see any in any catalogs. Come to find they shouldn’t even be there.
Seems like if I replace the cab mounts and take the bed spacers out the bed will be lower than the cab (cab raised by new mount and bed lowered with spacers removed) The sills are all 2 1/4” which LMC shows them all being the same. I think the thinner sill (above the rear end) might be in the wrong spot. If I remove the spacers, that will be the pivot point making the rear sill float up in the air as the fronts lower, Bed to cab gap is a little off. It’s about 1-1/4 on the bottom and 2” on top. So about 3/4” different. Spacers are 1-1/4” Last edited by Mbeef61; 06-18-2019 at 09:15 PM. |
