Old 11-30-2003, 07:05 AM   #1
TIMSPEED
TIMSPEED's Avatar
What psi are you guys running your tires at?
On my 255/55 17's, I'm currently running them at 25psi (cold) all around...should I raise it to 30psi? 35psi? The entire weight of my truck with a FULL tank of gas is 3620 and the load rating for each TIRE is 1875lbs...so..
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-30-2003, 05:00 PM   #2
apstguy
LED King
apstguy's Avatar
32-34 is standard. Running it at 25 can cause loss of fuel economy and can cause the tire to overheat.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 11-30-2003, 06:15 PM   #3
TIMSPEED
TIMSPEED's Avatar
I shall raise them up to 32psi then...see if I can't score 12mpg...of course, at that higher tire pressure it's gonna be HARD to get traction AT ALL!
See Them Here
Old 12-01-2003, 05:38 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Its called "feathering" Tim
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-01-2003, 06:56 AM   #5
TIMSPEED
TIMSPEED's Avatar
With 4.10's and a tight carb setting, it's called "VHT"
See Them Here
Old 12-01-2003, 08:53 AM   #6
bigblock73
yeller
bigblock73's Avatar
Originally posted by Riptide's 78p/u
go with whats imprinted on the side wall, usually around 30 psi. thats where I got my 295 50's and 245 60's
every auto teacher, tire shop employee, and auto enthuisast I have met have always told me to go by the vehicle reccomendations, NOT the tire specs. With that being said, I usually stay between 30-35 psi no matter what the weather is.
bigblock73 is offline   Reply With Quote
Old 12-01-2003, 01:13 PM   #7
low 84
low 84's Avatar
the pressure inprinted on the side wall is the maximum pressure for the tire. i wouldn't use this pressure unless you are at the maximum load rating of the tire also
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-01-2003, 03:31 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow
I have allways run mine @ 35 psi.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 12-01-2003, 10:55 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i run regular 15 inch tires on my truck and i keep em at 35lbs as per the sidewall guidelines
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-01-2003, 11:16 PM   #10
BaggedC10
Under construction!
BaggedC10's Avatar
33-psi here.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-01-2003, 11:29 PM   #11
TIMSPEED
TIMSPEED's Avatar
Originally posted by BaggedC10
33-psi here.
DAYUM! LoL, this is gonna be funny...When my tires are at full 33psi, I'm gonna be smokin em' for a mile!
See Them Here
Old 12-01-2003, 11:52 PM   #12
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
Right around 32-35 for me most of the time. I know what you mean about traction........my 94 Z28 has pretty much every bolt on that can be done to it, 6 speed trans, radial tires and 4.10 gears......my best 60' was a 2.2 lol. My 87 GN I had had a best 60' of 1.79 on ET Streets and about 5-7 lbs of boost at launch.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 12-02-2003, 06:28 PM   #13
crackajacka
Stylin
crackajacka's Avatar
is that 35psi hot or cold?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 12-02-2003, 07:43 PM   #14
1FaastC10
1FaastC10's Avatar
Brad
drop the pressure at the track, i'll bet you money that your 60' improves.
1FaastC10 is offline   Reply With Quote
Old 12-03-2003, 11:24 AM   #15
ItsNotABlazer
I would kinda doubt it with radials and that much power and 4.10 gears. I thought about putting some et streets on it but the weak link (rear end) would show up then I am sure and I do not have the money for a good 12 bolt right now lol. The car ran a 13.2 witha 60' of 2.2 but the MPH was 107 so it was coming on strong once it did hook. This was also on a 100+ degree day. It should be a solid mid 12 car with some decent tires. If I ever get the money for the 12 bolt it will definitely get a little giggle gas.
Brad
2000 BMW 740iL
Old 12-03-2003, 11:46 AM   #16
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Non Driver!! j/k
lol.. I used to cut high 1.8's and constant 1.9's and 2.0's on stock rubber on my 95 Formula(M6) and all the other guys cars in the club hehe.
5-7 lbs of boost only?? you scared??? hahahaha I used to leave the line in our GN at 25 lbs of boost LOL. cut 1.5's hehehe
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 12-03-2003, 11:58 AM   #17
LOHRTBT
LOHRTBT's Avatar
Oh yeah.... I run right at the tire max pressure
not the seating pressure...but max running pressure..to protect the wheels in case of holes in the road!
~Dave~
Old 12-03-2003, 12:48 PM   #18
arveetek
Ultimate Diesel Dude
arveetek's Avatar
I run 65 psi in the front and rear when unloaded, 75 psi in front and 80 psi in the rear when hauling my trailer.
Oh yeah, I'm running 16" 10 ply TRUCK tires!!
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 12-05-2003, 02:22 AM   #19
jimfulco
79 Sub, 255/70-15 TA's @ 36# all around.
jimfulco is offline   Reply With Quote
Old 12-05-2003, 10:37 AM   #20
ItsNotABlazer
Actually Dave I have only had the Z28 to the track once so far. I went to SLP customer appreciation day back in March (I think it was) held at Texas Motorplex. Lets just say track conditions were not optimum that day. Pretty chilly and windy........I think with some practice launching it I could get some 1.9's anyway on radials. The GN would not hold any more than 5-6 lbs of boost off the line. Previous owner of it had went a 7.7 in the 1/8th......my best with a leaky header was a 8.5ish......plus I outweighed previous owner by 100 lbs probably so theres a .10 loss right there. It used to belong to a guy who worked for Bennett Racing in Alabama. I bought it from the guy who got it from him. I thought it was kinda odd someone like Bennett racing employee having something besides a Mudstain.
Brad
2000 BMW 740iL
Old 12-05-2003, 10:59 AM   #21
LOHRTBT
LOHRTBT's Avatar
Brad
Cool!! Post up some new #'s when you get em.
~Dave~
