Old 06-18-2019, 07:17 PM   #1
Ptjsk
Tricks on Removing Side Panel Trim?
I'm going to attempt to remove my lower trim on my '72 Jimmy so I can take them in for restoration.
Is there any helpful advise I should know about prior to attempting the removal?
How are they secured to the body? Are they bolted through with nuts on the inside?
Any advise is greatly appreciated.
Pat
Ptjsk is offline   Reply With Quote
Old 06-19-2019, 02:57 PM   #2
notsolo
notsolo's Avatar
Re: Tricks on Removing Side Panel Trim?
All of the above, 47 yrs of anything goes...some double sided sticky tape, some bolts thru to the back some snap on clips....Blue tape around area near clip...thin flexible putty knife or 2, under trim slide in check by feel what's there, snap clips push both ways to release...Good luck.
notsolo is offline   Reply With Quote
Old 06-19-2019, 05:33 PM   #3
simicrintz
In areas where it is attached with double stick tape I have had success using fishing string to remove. Grab the ends of the string and pull back and forth while going from one end of what you are trying to remove to the other. Works well and does not scratch the paint!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 06-19-2019, 06:02 PM   #4
jaros44sr
jaros44sr's Avatar
don't be surprised if a PO just put sheet metal screws in to hold in place, some of mine were
to quote notsolow" anything can happen in 50 years"
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-19-2019, 11:39 PM   #5
parb
My 72 Jimmy had it's side panels attached with sheet metal screws.
parb is offline   Reply With Quote
