Old 06-18-2019, 09:05 PM   #1
Submariner616
Active Member
65 K20 Instrument Cluster removal
How do you remove the instrument cluster on a 65 K20? I have disconnected the speedometer cable and removed the 5 screws. The only other thing the manual says is to disconnect the oil pressure line, which I did not do because I have slack in it. It will not budge!
Do any of the switches have to be removed first? Are there secret clips I need to un-hook? Is there a special password I have to say?
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 06-19-2019, 06:42 AM   #2
PGSigns
PGSigns's Avatar
Re: 65 K20 Instrument Cluster removal
You have to pull all the switches and the choke cable. Most of the time there is a union in the oil pressure line just outside of the fire wall. Next I also disconnect the wiring harness. The bottom of the cluster can get hung up on the dash and some time you need to bend the tabs that stick up down just a bit to get them to clear. They get hung on the back of the bezzel and the harder you pull the tighter it will get.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-20-2019, 12:27 AM   #3
Submariner616
Active Member
Jimmy
Thanks Jimmy. I'll give it a try!
Submariner616
