Old 11-30-2003, 09:37 AM   #1
714x4
Preparation for Disassembly
What's the best way to remove the 32 years of crud from the under carriage, drive train and engine of my truck. I'm getting ready to disassemble her for a rebuild and I would like to remove as much of the dirt and grease as possible.
714x4 is offline   Reply With Quote
Old 11-30-2003, 10:09 AM   #2
Vince M
Vince M's Avatar
I use a high pressure washer. If you don't have one you can rent them. Quick and easy.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 11-30-2003, 11:24 AM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Go rent a steam pressure washer. They will remove any grime that you have. 180 degree water will do the trick...
67Fleetsidedream is offline   Reply With Quote
Old 11-30-2003, 11:43 AM   #4
74bowtie
If you can goto the carwash, Then you don't have to clean the mess you make on the ground when you are done. They have degreaser and good pressure to get you started on the cleanup.
69 Chevelle (Summer only ride, love to drive this)
72 Chevy Shortbox 4x2 (newest addition)
83 Chevy Shortbox 4x2 (project but its clean)
2001 S10 Ext. Cab 4x4 (daily driver)
74bowtie is offline   Reply With Quote
