Old 11-30-2003, 12:33 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Gas gauge bounceing
My gas gauge flicker between 1/2 and 3/4. I have replaced the sending unit and the resister on the back of the gauge its self. When I disconnect the wire to the sender my gauge goes to full so I know that’s working. Any Ideas on where to look next????
This is driving me Nuckin Futs.
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 11-30-2003, 12:47 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
gound wire may not be making a good connection check tht maybe the wire to the connector is bad too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-30-2003, 12:58 PM   #3
1970 CST Short Wide
Senior Moment
I only see 1 wire to the sender, anybody know where the ground might be???
Pittsburg Ca
94565
Old 11-30-2003, 01:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The bolts holding the tank in is the ground.
Corrosion is common.
Old 11-30-2003, 02:46 PM   #5
zyggy72
Can't kick the addiction!
Check the whole length ofwire going to your sending unit. It sounds as if sending unit wire is chafed through and is grounding out on the body or possibly even the gas tank. I had the same problem and found that the way that the sending unit wire looped over and behind the gas tank chafed through the wires jacket.
Hope this helps
zyggy72 is offline   Reply With Quote
Old 11-30-2003, 02:55 PM   #6
1970 CST Short Wide
Senior Moment
Thanks for all the info guys. At least I have somewhere to look now
Pittsburg Ca
94565
