Old 06-20-2019, 06:53 PM   #1
siggyfreud
siggyfreud's Avatar
Preload on Masster Cylinder?
Hey all,
Installing a Baer Master onto a GM hydroboost unit. I have about .100" of preload when the two come together. Baer says there should be no preload, Hydro vendor says all GM MC's have preload and it's normal.
Not sure who to believe lol.
Anyone have thoughts on this?
siggyfreud is offline   Reply With Quote
Old 06-20-2019, 07:09 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Preload on Masster Cylinder?
I would say "no" to the preload.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-20-2019, 07:39 PM   #3
Chris_oz
Chris_oz's Avatar
I think the 0.100" may be enough to give you issues.
The piston must be able to fully retract so the bypass hole is uncover. otherwise the brakes will lock
Chris_oz is offline   Reply With Quote
Old 06-20-2019, 10:58 PM   #4
siggyfreud
siggyfreud's Avatar
That's my thinking. Not sure what to do since the hydro unit isn't adjustable, and neither is the master. Baer makes a spacer that is .17", but that would likely be too much gap. So my only option would be to get it, and mill it down. Just sucks since this should all be plug and play!
Old 06-21-2019, 02:37 PM   #5
siggyfreud
siggyfreud's Avatar
Got the Baer measurement tool and checked it out. Looks like I need about .100" of space or so. I have a spacer that is .17" coming, but I might just try shaving the bullet that goes inside the MC first.
Old 06-21-2019, 09:03 PM   #6
68Gold/white
NO WAY on ANY preload!!!
68Gold/white is offline   Reply With Quote
Old 06-22-2019, 01:17 AM   #7
Madkidd007
Madkidd007's Avatar
Well being as it’s hydroboost it’s a little different story then you would normally think. The hydroboost will take some of the preload, no saying all of what you have. Your brakes won’t lock up because of this either, not like it’s fully depressed. Now when I did my hydroboost I just kept removing my pushrood, grind it, reinstall. I wouldn’t put a spacer in there when you can just grind the pushrod down. I can’t tell you how much preload mine has but I would say it’s about 1/2 the thickness of a standard 3/8 flat washer. Drive my truck everyday for the past year with no warped rotors or worn out pads, can also push the truck by hand.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-22-2019, 01:20 AM   #8
siggyfreud
siggyfreud's Avatar
How do you remove the pushrod? I was just going to mill the master cylinder bullet down.
Old 06-22-2019, 01:25 AM   #9
Madkidd007
Madkidd007's Avatar
The pushrod between the two should just pull out. Also keep in mind I would never machine a wear item. Say your master goes bad and your out of town or just not where you Can machine your new one. I always modify brackets or non wear items to fit parts that can wear or brake.
Old 06-22-2019, 01:28 AM   #10
Madkidd007
Madkidd007's Avatar
A couple google images to show the two styles that I’ve seen before. Mine is like the one circled in red with no retainer
Old 06-22-2019, 03:21 AM   #11
siggyfreud
siggyfreud's Avatar
Thanks. You'd mill the pushrod over the mc bullet? This is what in talking about taking about .07" off the back of. https://baer.com/Bullet-1-1-8.html
Old 06-22-2019, 02:22 PM   #12
Madkidd007
Madkidd007's Avatar
Yes I took metal from my pushrod, I’m unfamiliar with the aftermarket setup so is that piece you put the link, go between the master and hydroboost? If it’s not a part that is specific to either but acts just like the pushrod on a stock setup then Drill then end and refit till you’re just a tiny gap and bolt it down.
