What transmission fluid are you using in your turbo 400 transmission
What tranmission fluid do you guys use in your Chevy turbo 400 transmission?
Re: What transmission fluid are you using in your turbo 400 transmission
I used a synth blend of Dexron VI for a filter/refill of a 69 Elky I was working on.
Older transmission require dextron III. Dont use new VI in older transmissions.
At the body shop.
Type F
" That didnt make it any newer " " Dont antique the equipment " |
#5 | |
From a GM tech bulletin: Although DEXRON-VI (fig. 1) was introduced into production starting with 2006 model year vehicles (see bulletin 04-07-30-037D), there are still some misunderstandings about it. Here are some facts to help clear up these misunderstandings. Since GM introduced the first service-fill specification for automatic transmission fluid (ATF) in 1949, it has been necessary periodically to upgrade the specification as part of a continuous improvement strategy. The upgrading process ensures that available service fill fluids are of an appropriate quality for use in transmissions that have been designed around the improved factory fill fluid performance. IMPORTANT: As with previous upgrades, DEXRON-VI fluids are designed to be backward compatible with earlier transmission hardware. But more important, earlier type fluids are NOT FORWARD COMPATIBLE with transmissions that were designed to use DEXRON-VI. DEXRON-VI can be used in any proportion in past model vehicles equipped with an automatic transmission, in place of DEXRON-III (for instance, topping off the fluid in the event of a repair or fluid change). DEXRON-VI is also compatible with any former version of DEXRON for use in automatic transmissions. TIP: Simply topping off the fluid is adequate, but a full drain and replacement is preferred, to obtain the full benefit. |
Dex III
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
![]() Join Date: Feb 2009
Rebuilt 400TH and am using Mobil-1 Delvac. Most transmission shops would recommend the familiar route, which is Dexron III. I've heard from a few with solid experience that Delvac is a step-up on a rebuild, so giving it a go.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Type F. It is what was suggested with my new B&M torque converter
![]() Join Date: Dec 2009
Type F
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) Member # 75572 http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I put Type F in my TH350 big improvement in shifting over Dextron
71 C-20 07 Magnum RT AWD |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Type F as per B&M shift kit recommendations. Shifts good....and has held up for many years.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Mar 2003
Type F here also
#13 |
LOL, maybe you can post a link to the thread you started about Mobil-1 Delvac!!!
#14 |
Type F here too.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
#15 | |
![]() Use at your own risk (rebuild & new only). Two educated presented opinions say if it meets Allison TEF-295 then it makes for a very cool, smooth & happy 400. Safe route is Dexron III ![]()
#16 |
I have a recently rebuilt TH350 trans and was told to get ATF 4+
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
