Old 11-30-2003, 12:56 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Mounting a divorced t-case?
I have a Dodge, divorced 205 that I am getting ready to build mounts for. It seem to have only 4 bolt holes. Anyone have any pics of a divorced case mounting?
I could use some suggestions on rubber and hardware.
Why a Dodge case? It has 32 spline yokes on all 3 shafts. I am using a 1250 joint on the input and 1410 joints on the outputs. This allows me to upgrade to a different trany someday as I really want to go to a 5 speed.
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-01-2003, 12:23 AM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
A customer just mounted one in his '79 c-30 along with a 60 front axle, 500 Cad & 545 allison auto. He used the Dodge crossmember that came with the 205. I think he had it bolted to the frame rails with no rubber. I don't know if Dodge had rubber there or not. I do know that the crossmember bolts up to the case without any rubber- I have a 205 Dodge case & crossmember here on my shop floor. I was thinking of the older chevy 205's "torq brace" round rubber mounts as a way to mount mine if i use it someday.
Another customer had a welding shop install a 4-spd. brownie in his grain truck. They mounted it steel to steel. It sounds like an old bull gear tractor tranny going down the road.
jeffspower is offline   Reply With Quote
Old 12-01-2003, 12:32 AM   #3
Scrub
Scrub's Avatar
Thanks,
I was thinking that a steel to steel mount would really be noisy. I think I am just going to yank the parts out of my dodge case an put them in my chevy case as the Dodge has the big stuff and it is really tight. I guess everything will interchange? except of course the input, which will have to be a 10 spine for my 465.
Oh yeah, you got a chevy 205 laying around. I need to know how deep to drill the mounting holes. I have a chevy box that wasn't drilled and I don't want to break in the case with a drill
Thanks again
Scrub
Old 12-02-2003, 12:40 AM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
are you referring to the four big bolts that screw into the top of the Dodge case? They go all the way thru the case.
