06-22-2019, 05:01 PM | #1 |
How to properly check fluid level for 400 turbo transmission
I have not owned a chevy in a long time. How do you properly check the fluid level for a 400 turbo transmission behind a chevy small block.
Do you check it while running and in park or neutral? |
06-22-2019, 05:04 PM | #2 |
Re: How to properly check fluid level for 400 turbo transmission
Warm in park, running.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
06-22-2019, 05:51 PM | #3 |
But not after an extended drive. Let it run for a few minutes, cycle through the gears, then check while still running.
06-22-2019, 05:54 PM | #4 |
Warm fluid, In Park, Engine running and on level ground.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-22-2019, 06:06 PM | #5 |
Warm fluid, In Park, Engine running and on level ground ,Wearing your Chevy hat .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-22-2019, 06:15 PM | #6 | |
06-22-2019, 07:25 PM | #7 |
Roadtrip!
Warm fluid, in park, engine running and on level ground, wearing your chevy hat, on a cloudy day.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-22-2019, 09:33 PM | #8 |
Only thing I can add to that is You must use a red shop rag to remove the fluid from the dipstick before you check the fluid level.
HeavyHauler I hope you got a Good sense of humor . Looks like we have took the (Fluid ) dipstick and run with it. .
06-22-2019, 09:58 PM | #9 |
Old member
Ya'll for got safety glasses, apron and face shield just in case!
