Old 06-22-2019, 10:25 PM   #1
Richard Jensen
alternate materials used for grills or modified grills
Hello,
I've been kicking around ideas for a replacement grill for my 72 C10 custom deluxe. I don't have a problem with a "custom" look. I'm afraid a repo grill will not be up to my standards vs the cost. I've looked at some of the bar type grills, billet is absolutely out of the question. Some of the newer grills they put on newer trucks, from the aftermarket look gaudy and most likely block way too much air flow. I though about a perforated sheet that is honey comb with 79% open area and then putting a air dam on the front to catch more air. I think stainless would look cool, but they don't make the Honey comb stuff like that. I could get it powder coated black or silver as the truck is black with the white cab roof, and that would look good, but not sure how well that would hold up to rock chips and such over time.
If you guys have any ideas or pictures of what you did lets see them!!!
Thanks!
Richard
Lead, follow, or get out of the way!
Richard Jensen is offline   Reply With Quote
Old 06-23-2019, 12:13 AM   #2
Getter-Done
Getter-Done's Avatar
Re: alternate materials used for grills or modified grills
How about this?
https://www.homedepot.com/p/M-D-Buil...8Pvw&gclsrc=ds
You could use this with your original grill Or??
84 Chevy K-20
Old 06-23-2019, 01:08 AM   #3
Richard Jensen
Hello,
I've got to go to Home Depot sometime this coming week, I'll check it out!
Thanks!
Richard
Old 06-23-2019, 10:28 AM   #4
flashed
My Repop grill was very nice and I like the stock grill over anything else I have ever seen but in to see what you come up with .
flashed is offline   Reply With Quote
Old 06-23-2019, 04:06 PM   #5
Sheepdip
Sheepdip's Avatar
The previous owner installed an after market grill that had no provision to open the hood unless you laid underneath on the ground then reached up to pop it open?????
Might want to clarify that a purchased after market grill has the access to you latch.
So I cut out a few bars, milled a picture frame with a skirt the same depth as the bars from a piece of billet aluminum and epoxied it in place.
I added the SS center bar because no turn signals either and of course the GMC emblem.
Sheepdip is offline   Reply With Quote
Old 06-23-2019, 04:18 PM   #6
un4gvn!
un4gvn!'s Avatar
I've seen at car shows grilles made from stainless steel brake tubing. If your into the copper color, you could try the copper/nickel tube. The imagination is a wonderful thing to use.
un4gvn! is offline   Reply With Quote
