Old 06-23-2019, 05:02 PM   #1
OutlAw_8
Trim clips
Another question, new to the rebuild process. I've got factory trim piece clips that are metal. How do I remove them? Could I grind them off to replace them? Any suggestions or advice would help!! Thank you
OutlAw_8 is offline   Reply With Quote
Old 06-23-2019, 09:42 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Trim clips
There either should be a nut on the back of the clip or you squeeze the clip together on the back side of the panel, then push it out. Spray a little penetrating oil on them. They come out easier then. I would try and save them. The reproduction clips that I bought with the repro trim I put on the '71 k10 when I rebuilt it did not work well. I ended up scrounging up enough originals to put it on. That's been a few years ago so maybe they have corrected the problem.
LockDoc
Leon
Old 06-23-2019, 11:29 PM   #3
Astro-Balls
Astro-Balls's Avatar
Re: Trim clips
Post a picture of the Molding and the clip if you can, we can help you on how to remove it.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
