Ignition Coil Bracket - Broken Bolt
I am in the middle of replacing my distributor, ignition coil, wires and plugs and noticed when I was removing the ignition coil that the bracket was only held on with one bolt rather than 2. After I removed it I could see why, there is a broken off bolt stuck in the hole.
I have tried a few different things to get it out. I tried using a screw extractor and that didn't work. I tried putting some POR-15 epoxy on it, let it harden, and then I made a slice in it for a screw driver, but the added epoxy piece just ended up breaking off. I also tried something similar using JB Weld, but got similar results. I also tried drilling it out, but I don't seem to make any progress. Any suggestions on how to get this thing out? |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Ignition Coil Bracket - Broken Bolt
A lot of penetrating oil. Then start drilling with small left-handed drill bits. Don't go to deep (through the bolt). Go slow and keep stepping the bit size larger. Hopefully a bit will grab and spin it out. This works most of the time for me. Good luck my friend.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Soak it in PB and let is sit for a bit. It will help if you can get the engine up to temp as the metal will expand slightly and make it easier for the PB to soak through.
Drill into it with the tiniest bit you can, like 1/8th". I will be worth buying a new bit if you don't have a good one. 1/8" bits are pretty cheap. Go slow, keep it lubed up, and try to stay in the center as best as possible. You want to get down a significant bit - 1/4" or so. Hammer the screw extractor into the hole to get the best grip you can. You want the screw extractor to grip on the sides and not bottom out. You might want to take the blow torch to it to get it hotter and help the PB soak in. Kind of scary on a manifold though.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Id just tighten down the one with a good star washer. That should hold it and keep it from rotating any.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Who Changed This?
![]() Join Date: Jan 2013
When you drill for the EZ-Out, use a left-handed drill bit. Sometimes the bit will catch and unscrew the broken bolt for you. If the bolt is bottomed out in the manifold, that may not work, though.
Moderator
![]() Join Date: Jun 2017
When using the left hand drill bit, make sure you run the drill in reverse....yep, seems common sense, but I have seen several instances of "it wont drill into the bolt" !!!!!!
Be careful drilling that bolt out, that looks like an aluminum manifold and they are very soft....that bolt most likely snapped off due to excess length....bottomed out and someone just kept turning.... You could always mount the coil somewhere else... Or... just bite the bullet and go for a HEI dist....just make sure you replace the resistor wire...search on the board and you will find lots of posts about converting points / coil to HEI.... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() Last edited by AussieinNC; 06-24-2019 at 07:55 PM. |
#7 | |
Who Changed This?
#8 | |
Moderator
Even better now are the clowns that tighten a sump plug on an alloy sump....and strip out the soft threads in the alloy...then add misery to the pain by using some "sealant" to stop the drip... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#9 | |
Who Changed This?
