06-24-2019, 05:08 PM | #1 |
pulleys again
I think I have the wrong water pump pulley? I bought a used 307 engine and the water pump pulley was just sitting on the pump. now I am attempting to install the belt and the crank pulley is about 1/8 inch set back compared to the water pump pulley. I pulled the crank pulleys off and they look original, they are stamped 44043bagm and 51232bbgm. what would be a matching water pump pulley part number? this engine has the short water pump and is running power steering. thanks for any help
06-24-2019, 06:17 PM | #2 |
Re: pulleys again
I don't think a 307 came with a short water pump.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-24-2019, 06:28 PM | #3 |
Re: pulleys again
well if that is true I have an even bigger mess to deal with? the waterpump that came on the engine was the short pump and had signs of leakage so I bought a new one. so do you think I if buy a long water pump all the pulleys will work?
06-24-2019, 06:43 PM | #4 |
Who Changed This?
Re: pulleys again
Take the new pump back to the parts store and set a long water pump next to it for comparison.
06-24-2019, 09:12 PM | #5 |
Re: pulleys again
My 69 short step with its factory 307 certainly did.
OP didn't say what motor was out of but I would think Google would be a good source of part #'s for pulleys and figuring out what he has versus what he needs.
06-24-2019, 10:11 PM | #6 |
Re: pulleys again
I'm in Cobleskill which isn't that far from you.I have a bunch of these trucks.I can help you out.Dennis 518-234-2480 or 518-528-2646 cell
06-25-2019, 09:04 AM | #7 |
Re: pulleys again
06-25-2019, 11:43 AM | #8 |
Re: pulleys again
Just my 2 cents. That pully shaft is just a pressed fit so it could be out or in to far. I got a shorty for my 327 and had the same problem, so I put it in a vise and pressed it in a little. If it's in to far you might need to get creative to pull it out.
06-25-2019, 12:56 PM | #9 |
Re: pulleys again
I had exactly the same problem when i swapped in a 350 for my worn out 307. It was a short water pump on the 307. Swapped the pulleys over to the 350 and the crank pulley was in about 1/8". I checked and the alternator and water pump were in perfect alignment. I ended up buying a spacer from speedway. Works perfectly now.
06-25-2019, 12:59 PM | #10 |
Re: pulleys again
Like this. Don't forget that you may need longer bolts as a result.
https://www.speedwaymotors.com/Speed...YaAheQEALw_wcB |
06-25-2019, 07:21 PM | #11 |
Re: pulleys again
I considered doing that,however the pulley on the water pump has a narrow space at the rear and if moved back it may contact the water pump. I was hoping somone had an old part catalog that could confirm the part numbers needed to make the whole set up work.
06-25-2019, 07:33 PM | #12 |
Re: pulleys again
little more info. the 307 engine I bought was supposed to be out of a 1970 c20.the engine had a.c brackets on it but no compressor. I am going to be adding p/s
