C20 2wd leaf spring 72 rear brake adjuster arm
I am trying to finish work on my 1972 C20 brakes, and it does not appear that they make an automatic brake adjuster arm for leaf spring trucks. The ones I see are for coil spring trucks, and they are smaller. Does anyone have one or know a source for new ones? I will try to rob another differential I have if I can win the battle of decades of rust and get it apart.
Who Changed This?
![]() Join Date: Jan 2013
Re: C20 2wd leaf spring 72 rear brake adjuster arm
Can you post some pics? Those parts are common as dirt and should be readily available. A couple of years ago I went through this with parts that were "boxed wrong", in parts store lingo. I don't think that coil Vs leaf springs make a difference, but I can be educated.
I have a Dana 60 differential. What do you have?
![]() Join Date: Jul 2016
That arm is not available, some people say the strut is available but I haven’t seen it. I sell the arms and struts all the time, same story on the 12 bolt rear ends, not available.
I have one set left for a dana 60, 2 struts and 2 arms, $60 shipped. |
![]() Join Date: Mar 2003
I've actually got a 60 I'm taking apart right now and putting disc brakes on for a customer so ask away. 71-72 rear
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
All those brake parts are still available if you know how to look for them, the key is being able to find the factory part numbers. Amazon has the struts and the adjusting levers for like $10 delivered. Don't mean to step on any board members toes but that's why most good mechanics wear steel toed boots. https://www.amazon.com/Dorman-21149-...let+C20+Pickup Heres the "LEFT" adjusting lever, note that they are left right specific https://www.amazon.com/Raybestos-H25...let+C20+Pickup, You can use Rockauto.com to look up parts and part numbers. Amazon Prime is a great tool as well...Good luck!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#6 | |
#7 | |
#8 | |
And if you think that k-Martish dormant 21149 part is the same as these originals your fooling yourself. Here is a picture of the correct parts for your reference for when you don’t find the levers on amazon, rockauto or whichever.
Thanks for the posts. Some of the links take you to the same place I stared when I was just going for new ones. My main suppliers only had the arms for coil, not leaf. There is a difference on this differential. I finally got time to tackle two other differentials. The first one came apart easily...to easy, as I probably sold the brake parts to a customer a few years ago. The second one was a tough go, but I got it apart. The attached shows what I needed. I will get back to finishing the brake work, now that I have taken the grandkids fishing as promised.
#11 | |
