Old 06-28-2019, 08:34 PM   #1
Kevinn
Need help identifying what this switch does and mount ?
I need help where this switch goes and what does do? Also if its important?
Kevinn is offline   Reply With Quote
Old 06-28-2019, 08:48 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Need help identifying what this switch does and mount ?
It's a brake light switch. It is supposed to go on the brake pedal bracket under the dash. I have no idea what it's doing laying on your valve cover unless the PO used one for some other purpose.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 06-28-2019, 09:10 PM   #3
weim55
That’s the transmission electric kick down switch for the turbo 400 behind your big block. I believe it attaches to the left rear carburetor stud. I’m guessing one of the guys here on the board with an original 68 to 70 396 turbo 400 could set you up with a picture of the proper mounting and the way the switch mates to the original quadrajet carburetor.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 06-28-2019, 09:25 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup, attaches at the left rear bolt. The lever on the throttle arm has a 90º bend that presses on the plunger (which is to the front). Can't see it in your picture, though.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-28-2019, 10:08 PM   #5
HO455
Post Whore
HO455's Avatar
This link and its links should help explain the placement. There is no big block information but if you do a search you should get luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=771120
RIP Bob Parks.
Old 06-28-2019, 11:32 PM   #6
Bahn112
Can't help, i'm just glad that i'm not the only one who looks in/around my truck and sees a bunch of wires/plugs that don't seem to go anywhere.
Bahn112 is offline   Reply With Quote
Old 06-29-2019, 12:05 AM   #7
FirstOwner69
FirstOwner69's Avatar
To me, it looks like a brake light switch (per post 2) that has been re-purposed as a kickdown switch.
FirstOwner69 is online now   Reply With Quote
Old 06-29-2019, 10:38 AM   #8
100%Chevy
The switch is up-side down in the pic.
I have it on my 68,C-10 with a turbo-400.
It mounts the same on my 327 and big blocks.Both engines use the quadrajet and it mounts on the left rear carb stud.
Mike.
100%Chevy is offline   Reply With Quote
Old 06-29-2019, 12:15 PM   #9
FirstOwner69
Here's a picture of the original on my '69 with a 350 and TH400.
Old 06-29-2019, 07:30 PM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
At first glance I thought it was an idle control bracket for the TCS solenoid but since the OP has failed to respond with more pics and explanation's, we can only speculate? Is that a single orange/red wire? Where does the wire(s) go? He appears to have a big block so is this in fact a repurposed brake light switch? "Pics and more info please?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-29-2019, 08:47 PM   #11
Kevinn
I'm %100 sure it's not the brake light switch since my brake pedal already has one but I followed the wires it goes to the th400 transmission side if the pan.
Old 06-29-2019, 08:52 PM   #12
Kevinn
I'm amusing it could be the kickdown switch because i notice when I give it the beans the trans doesn't downshift just stays a high gear
Old 06-29-2019, 08:57 PM   #13
Kevinn
It's a 1970 c10 with 396 bbc with th400 transmission.
Old 06-29-2019, 11:14 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
If it has 4 connectors on it, and a 4-connector jack, it is indeed the kick down switch. It doesn't actually look like the switch on my truck, though. That's why Rod'n'Rudy is calling it a stop light switch, because it doesn't look like the kick down switch.
The kick down switch would be "normally open" in electrical talk, and that doesn't work with the pictured switch, since the connection is made when the throttle is wide open, or nearly so, and the switch for the brake lights is "normally closed", but held open by the brake pedal return spring.
Bottom line, if that switch ain't connected, and doesn't have 4 blades, it ain't a kick down switch.
Maybe what FirstOwner69 has posted works, too, but it isn't what my setup looks like.
~Steven
Simi Valley, CA
Old 06-30-2019, 12:15 AM   #15
Kevinn
Thanks for the info ..here's another picture of switch.
