Old 06-28-2019, 09:09 PM   #1
phraza
phraza's Avatar
Will my rally wheels fit discs?
Hey all
Swapping over to front discs soon, and my truck has rallys (15x8), but I’m not 100% sure if discs will fit, I know there was a diagram somewhere comparing the old wheels and the newer rallys that fit.
Pic of the inside of one of my wheels, I can go take the wheel off if it makes it easier to see
Cheers!
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 06-28-2019, 09:22 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Will my rally wheels fit discs?
Those AFAIK only came on disk break trucks.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-28-2019, 09:43 PM   #3
phraza
phraza's Avatar
That would be awesome if they are sweet! Just took the wheel off, here’s a better pic attached
350 V8
Build thread here
Old 06-29-2019, 12:04 AM   #4
Captainfab
60-66 Nut
Yes those 6 lug Rally wheels will work with disc brakes as long as you stay with stock size rotors which are just under 12" in diameter.
Old 06-29-2019, 12:05 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Mine does!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-29-2019, 12:46 AM   #6
phraza
phraza's Avatar
Wicked!!!
I’ve just ordered these from Early Classics. Doesn’t say actual diameter, will drop them a line just to make sure
https://www.earlyclassic.com/node/154
Cheers
350 V8
Build thread here
Old 06-29-2019, 12:55 AM   #7
phraza
phraza's Avatar
Just looked on their site and they are 12”
https://www.earlyclassic.com/taxonomy/term/72
Which is good!
Thanks for the advice all!
350 V8
Build thread here
Old 07-03-2019, 02:17 AM   #8
MOJO1963GMC
MOJO1963GMC's Avatar
I have the Early Classic kit on my '63 with Rallys off a '78 Chevy. 15X8s. I havent had any problems
MOJO1963GMC is offline   Reply With Quote
Old 07-03-2019, 03:43 AM   #9
phraza
phraza's Avatar
Wicked, thanks mate! Appreciate the reply
350 V8
Build thread here
Old 07-12-2019, 01:54 PM   #10
65chevysub
65chevysub's Avatar
I had 86 Suburban rally wheels on my 65 Suburban. I had changed to 5 lug disc in the front, and traded chrome smoothies for them. At one time even had them painted the body color. With the chrome ring and center caps, it looked good.I started with the 6 lug version before I switched to the 5 lug
65chevysub is offline   Reply With Quote
Old 07-12-2019, 04:21 PM   #11
65chevysub
65chevysub's Avatar
Here's my burb with the 5 lug 86 Suburban Rally wheels
Old 07-14-2019, 06:20 PM   #12
65GMChevy
I have 15 inch Rally's and my 12 inch rotors might have worked but I have the big GM dual piston calipers and they hit. Good Luck!
65GMChevy is offline   Reply With Quote
Old 07-14-2019, 07:36 PM   #13
65GMChevy
