wheel base?
does anyone know the factory wheel base of 72 chev p/u ( long bed and short bed)
Try the search function. I think this has been covered somewhere before. Hope this helps.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Formerly yellow72custom
LWB is 127", SWB is 115" if i remember correctly
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
its all about the +6 inches
That is correct.
Then there is the longhorn in 3/4 and one tons at 133 inch and the 157 inch one ton also. |
![]() ![]() Join Date: Jan 2002
What is the wheel base for a long step bed is it the same as the longhorn.
a long step would be a 127, but a one ton step with the 9 foot bed would be the 133 chassis like the longhorn.
