Old 06-30-2019, 06:24 PM   #1
shp4man
shp4man's Avatar
Plywood bed floor under $100..
There's a thread in the 67-72 section about plywood bed floors, but thought I'd post here.
My truck's a '65 long stepper with completely rotten OEM bed wood. It's a patina style truck with good mechanicals but faded paint/some rust
..anyway, the bed is actually about 4 x 8, just like a sheet of plywood.
So have been researching the different plywood grades, and hardware replacement from the cheapest sources.
I figure I can do a good, long lasting bed replacement for under $100. That's with some black or grey paint for the plywood and hardware and rust sealing.
I'm curious to see what it actually costs. It's always more, as you know.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 06-30-2019, 07:31 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Plywood bed floor under $100..
If you measure your bed you might find that it is 97" in length, 1" longer then a piece of plywood.
I bought some pine and home depot for about $130. Will be milling and installing it soon.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-30-2019, 09:19 PM   #3
jayoldschool
Moderator
Yep, you need 10' lengths for a long bed. Cut shorter, of course.
jayoldschool is offline   Reply With Quote
Old 07-01-2019, 07:53 AM   #4
kens65fb
Could you point me to the post on the other board ?
kens65fb is offline   Reply With Quote
Old 07-01-2019, 11:29 AM   #5
verdell
verdell's Avatar
I ended up doing this last year for under $80.00. Unfortunately, I didn't take pics of the finished product. I painted the steel strips and used stainless button head hardware. Just a sheet of plywood from Lowe's. It came out ok and serves the purpose.
verdell is offline   Reply With Quote
Old 07-01-2019, 10:34 PM   #6
slepysal
slepysal's Avatar
how many sheets did you use?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-08-2022, 08:24 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Plywood cost is outrageous right now. You can get by with 8 feet and use a 1 x 3/4 hollow steel stock filler at the tailgate. I'll get a pic tomorrow.
66 C20 Service Truck:
Old 04-08-2022, 10:01 PM   #8
LostMy65
LostMy65's Avatar
Oh, and the chemicals used in Pressure Treated plywood will likely corrode metal.
Old 04-08-2022, 11:23 PM   #9
Chevy Fleetside
`I used my table saw to cut the grooves. It was some work. I learned something. It is best to buy the wood wider and rip them down so it is next to the bolt holes on the cross sills. I never took the bed off of the truck.
Old 04-09-2022, 04:01 PM   #10
LostMy65
LostMy65's Avatar
Here's a scrap piece of 3/4x3/4 steel stock I used to mock it up.
And it's the same height.
Old 04-09-2022, 07:56 PM   #11
62bagger
62bagger's Avatar
I used plywood for my short fleetside. I had the plywood from another project. I am happy with the looks.
62bagger is offline   Reply With Quote
Old 04-14-2022, 03:04 PM   #12
LostMy65
LostMy65's Avatar
Looks good.
Old 04-14-2022, 03:09 PM   #13
LostMy65
LostMy65's Avatar
I ripped one sheet into two 20 inches, and the center sheet is about 34 inches. The strips are spaced at about 18 inches.
Old 04-15-2022, 03:22 PM   #14
KVB
KVB is offline   Reply With Quote
Old 04-15-2022, 03:23 PM   #15
KVB
Southern Yellow Pine is what was used originally, and it can be found pressure treated. Should last forever.
Old 04-15-2022, 06:02 PM   #16
LostMy65
LostMy65's Avatar
I'll mention it again, but others may want to do their own research, but I think the chemicals used in pressure treated wood will rust basic metal.
