Old 11-30-2003, 07:08 PM   #1
stan79chevy
stan79chevy's Avatar
i need help with a grill swap
i have pics this time. i have a 79 1/2 ton 4x4 chevy. i want to put in a 74 gmc grill. the gmc grill is to thick to fit in. another board member will give me the parts i need off a 73 he has to make it work i just need to know what i need. i know i need the center one. i took my center one out and stuffed the grill in and it hits on the side brackets, so i think i need some of those also. i dont want to hack the grill up if i dont have to.
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-30-2003, 07:09 PM   #2
stan79chevy
side brackets
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 11-30-2003, 07:11 PM   #3
stan79chevy
heres a better pic of the side bracket
im sure someone has put this older style grill into there newer truck. i just need help with what parts i need to make it work..thanks
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 11-30-2003, 07:25 PM   #4
bigblock73
yeller
bigblock73's Avatar
I don't think those "side" brackets come off...in fact, the 73/74 grill bolts to them. I am guessing the core supports are different then and in order to put in that grill you will need to convert to an older one (core support).
bigblock73 is offline   Reply With Quote
Old 11-30-2003, 07:30 PM   #5
stan79chevy
i can take the brackets off mine
i took them both off actually and put the grill in there but that leaves nothing to bolt it to..a new core support wasnt the answer i was looking for. thanks any suggestions..i could cut those side brackets to make it fit
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 11-30-2003, 08:46 PM   #6
dswancutt
Grill Swap
I think I have the answer to your question. I checked my GM parts manual, and the grille brackets for 73 & 74 GMC trucks are different than those for your 79 Chevy. In fact, they are unique for GMC trucks for those two years. If you can get the brackets off the 73 that the other board member has, it should fit.
PS – What condition is you 79 grille in and what are you going to do with it.
Doug
dswancutt is offline   Reply With Quote
Old 12-01-2003, 12:19 AM   #7
stan79chevy
dswancutt
im throwing the 79 grill away..its cracked, cut, broken, and held together with zipties..i know the grill is a 73-74 only grill. with side brackets and the center one you think it will fit?
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 12-01-2003, 01:12 AM   #8
dswancutt
Grille Swap
I checked the parts manuals again, and the core supports are the same from 73 to 80. So as long as you have the side supports AND the center support, you should be good to go. I would suggest going to a GM dealer and getting the oval shaped nuts that hold the grille in. The GM part number is 06271829, group 2.729
Doug
Old 12-01-2003, 01:52 AM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You will need everything that bolts to the core support off the 73 for it to work. Outside and center supports AND the hood latch. As was stated before, the core support was unchanged from 73-80. The other parts however were specific for 73 and 74 ONLY.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-01-2003, 03:01 AM   #10
stan79chevy
the hood latch would be different too?
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 12-01-2003, 12:32 PM   #11
Captkaos
Captkaos's Avatar
The pull for the latch is located in the certer of the grille for 73 and 74 only, so you need the latch release.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
