Gas guage ?
Can a gas gauge be reset? My needle is stuck in the 3 o'clock position. Can this be fixed? How can I tell if it will work or not? How do you tell if a sending unit is working or not?
Dumb question...Where is the oil pressure sending unit on a 292?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
Inline 69
sounds like your not getting power to the sending unit,,,,if you disconect the brown wire from the sending unit of a "known"good unit ,it will do exactly what yours is doing,,,jeff
KEEP ON TRUCKING
mine is the sameway i take wire off sending unit it goes to the 3oclock position put wire back on and it drops to empty just havent had time to fool with it any tips would be great
72 cheyenne 2wd lwb 71 k20 sons bassett va |
72 shadetree. mine did the same things. but mine prob reads empty because im out of gas
70 longbed 496/th400/Ford 9" |
#5 | |
KEEP ON TRUCKING
Mine did the exact same thing. Bought a new one from GMC Paul's and after installing it the problem was gone.
Alex 1971 Lil' Red 350 SBC 700R4 |
#7 | |
Martin Gibson
USAF Retired 1964(-ish) C10 |
its all about the +6 inches
Slide your seet forward and look at the tank. There should be a small brown wire on the sending unit. If you were to follow that wire, odds are it is broken somewhere. under the door sil plate is a very common place.
It may well be unplugged from the fuse box too. Shade. It sounds to me like your float is filled/missing. Could also be a bad sending unit, but you could find that out by testing the unit when you pull it out to see if the float is full. |
