KEEP ON TRUCKING
lost brake lights and one rear signal and discovered that you can wiggle the turn signal lever and they work
how hard is it to replace the signal switch thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Formerly yellow72custom
It is really easy....pull off the steering wheel, and take out the switch....i did it about a year ago....think it took less than a hour. I don't rember how to explain it...but it is really straight foward, even for a clutz like me
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Living In The Past
had something very simular happening with my friends 70. we pulled it down to where the switch is exposed then hosed it down with electrical contact cleaner and it started working again. If you do pull it out it is very straight forward. The only area that might be a problem is maybe fitting the wire plug through the rubber gromet without cutting or breaking it. On the one I did the PO had already cut that grommet so I dont know how hard it is to get it through
![]() Join Date: Dec 2001
It's pretty easy to do. If you disconnect the wires from the connector before you thread it through the grommet, you'll be alright.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Cause the Chicks DIG IT!!
I just got done replacing a switch in my 71. The first question i ask though is do you have tilt or no tilt. The tilt will determine how easy it is or not. Now granted i put a tilt steering column out of an 81 van in mine but i would reckon it's the same. Just get you a steering wheel puller (you can rent them from autozone) and take off the steering wheel. The turn signal switch itself has 3 screws in it. NOw on my tilt i was able to wrestle it out from there but going back in was another story. theres an outer bracket that has the holes in it for your turn signal indicator and in my case the tilt lever and also the 4 way indicator switch. You can use a 2 jaw puller to take that off if you have that bracket. The bad thing i ran into was putting the new one back in. I had a small area to fit the connector plug through and it just wasn't happening. I had to cut the wires feed em through and then put em back together. after that it wasn't so bad. It's not really all that hard but look forward to a few small minor speedbumps in the road. Good luck
PICTURE'S WORTH A 1000 WORDS
The LMC catalog comes through again!
![]() Curse their high prices, but love those exploded diagrams! ![]()
KEEP ON TRUCKING
thanks its a non tilt shouldnt be to bad the worst part is i just swapped out wheels today lol
#9 | |
its all about the +6 inches
#10 | |
KEEP ON TRUCKING
Black 72 Chevy
Easy.
72 Chevy, SWB, 350engine, TH400 |
67-72 Addict!
Disconnect battery , you also have to push in hazard button to get the switch out. Take your time.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
