Old 11-30-2003, 08:55 PM   #1
Fletch
1977 K20 Trannys
Any of you 'old timers' out there remember what automatic transmission came with the 1977 3/4 ton 400 cu.in. Chevy 4x4 pickup trucks with the NP205 Full time four wheeldrive. I want to settle an argument with a friend, he said you could get a THM 400 with that truck. I remember the THM 350 was the only tranny that came with full time fourwheel drive, no matter what . What say you guys?
Fletch is offline   Reply With Quote
Old 11-30-2003, 09:55 PM   #2
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
If it is the NP205, its a part time truck.. The NP203 was fulltime and would have been a TH350 trans behind it, in 1977.... In other years you could get a th400 and in '74 you could even get a SM465 3spd manual on the full time 4x4...
Bottom line is that it is possible to find/build a full-time (np203) with a th400, they are uncommon though...
as for 1977 strictly, I dont think you could have gotten a th400/np203 combo because Ive never seen or heard of one.. But thats not fact. I think I have some brochures somewhere, or you could look at that one brochures site that grim reaper always posts..
mike
mike reeh is offline   Reply With Quote
Old 11-30-2003, 11:21 PM   #3
Fletch
Thanks Mike, I know my memory is a little fuzzy after 26yrs. I thought full time 4wheel drive was the NP205. But I do remember that I could not order the THM 400 in that truck, I went to several different Dealers. My friend insists he had one in his '77.
Thanks again.
Old 12-01-2003, 01:47 AM   #4
mike reeh
mike reeh's Avatar
another thing that popped into my head since you mentioned special ordering, was I went to look at a parts truck at this guys house and the truck was a '78 K20 that the guy special ordered from the factory, with a th400 and full time 4x4... The truck was in parts and he told me it was a th400.. looking thru the shed, I saw the t-case and knew it was a NP203, and so I say "are you SURE its a th400?" he says yes, he had to special order it.. I looked at the T-case adapter and sure enough it had the 6-bolt hexagonal pattern. So the general MADE em but I dont think they mass produced em for the normal dealer shipments.
On a side note, that setup is actually quite desireable to some parts seekers because the NP203+th400 adapter can be used to build a dual transfer case setup that would bolt to a TH400...... a TH400+NP203gearbox+NP205 would be about as bulletproof as you could get...
enough rambling.. hope this enlightened you some
mike
Old 12-01-2003, 10:46 AM   #5
77bowtie
In 77 with a 400cid engine the trany is a TH-400, For sure my Bonanza came that way!
77bowtie is offline   Reply With Quote
Old 12-01-2003, 03:42 PM   #6
Fletch
Boy, I must be getting old, I don't remember the Bonanza, was that a 4x4 Pick-up? Did you special order it with the THM 400?
Old 12-01-2003, 03:49 PM   #7
Fletch
mike
Ha! Me thinks I may have opened a can of worms!
Old 12-02-2003, 12:46 PM   #8
77bowtie
The Bonanza is/was a special promotional package. I checked Chuck's Chevy Trucks and in 77 all 400/454 engine'd trucks came with a 4-core radiator and a TH-400 tranny.
Old 12-02-2003, 12:58 PM   #9
77bowtie
Oh yeah...my 77 came with a np-203 tc too.
Old 12-02-2003, 05:19 PM   #10
Devil'S Ride
My 77 originally had a 400 an 203/TH400....course, Im the third owner, an when I got it someone had swapped the Th400 for a TH350.....an the 400 SB for a 350.....so, as far as I know...it came with TH400 and NP203....
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 12-02-2003, 11:19 PM   #11
mike reeh
mike reeh's Avatar
that is definately incorrect. my 77 K25 gmc was 400sb/th350/np203
mike
Old 12-03-2003, 11:59 AM   #12
77bowtie
Perhaps, Mike, perhaps.
Old 12-04-2003, 03:02 AM   #13
mike reeh
mike reeh's Avatar
I think that different areas (geographically) will see major differences in what GM put out.. Especially being that Im in california.. I dont doubt for a minute that they made th400 full timers.. but I do know that in the several years Ive been into the 73-87 4x4s, (mainly 77), ive never seen a th400/np203 truck.. and ive seen a LOT of trucks.. with the exception of the '78 parts truck in my previous post. That, coupled with the fact that I have seen many (including my own unmolested) 77 th350/np203 K25, brings me to the conclusion that yes you get a th350 OR th400 full time 3/4ton pickup thru the years.. one may be more common than the other (depending on location?) but they were both available. were they both available in 77? maybe. in fact- probably. Is it unreasonable to say that you could ONLY get a th400/np203 in 1977? Yes =)
mike
Old 12-04-2003, 08:49 AM   #14
1FaastC10
1FaastC10's Avatar
my uncle has a 79 K20 with a TH400/203 in it, and my grandpa had a 77 K20 with a TH350/205
1FaastC10 is offline   Reply With Quote
Old 12-04-2003, 12:48 PM   #15
77bowtie
Hey for enough $$$ GM could sell you a special order truck with GM electric diesel power. Look at all the CPO"S and the "muscle" cars of the 60's. I have found that not much is written in stone.
Old 12-04-2003, 07:01 PM   #16
Fletch
Well I was reading through ChucksChevytrucks pages, and it said the Th350 was the only tranny available from '73 to '76. And the th400 were 'available' from '77 & later. So that means that 1977 was a transition year and possably early 1977's had the th350's & later models had th400's if you chose to order so. When buying my 1977 I decided to go with the 2wd for two reasons. Nicer ride and I wanted the 454/TH400 combo, wich I know for sure did not come in the 4x4's. I would have settled for the 400SB/TH400 in the 4x4 but was told it was not available, this was in Jan. of 1977. BTW, I still have this truck, it's all original. I stored it every winter. See signature.
Old 12-04-2003, 09:25 PM   #17
TROYLV
400-203
got a 74 blazer with turbo 400 and 203 tc. it isn't a full removable top either. thought both were strange.
troy wilson
TROYLV is offline   Reply With Quote
Old 12-05-2003, 04:16 AM   #18
1FaastC10
1FaastC10's Avatar
consider your source. not very reliable information at all, as far as i can tell. one case that i can think of is the mention of the hood ornament being new for '86. that completely explains why the ragenrat has one, and 3 of the 81-83 trucks i have owned have had them. this was also verified trough GM parts catalogs, which list them back to '80. after that who knows, they're probably long discontinued.
Old 12-05-2003, 03:53 PM   #19
Fletch
[QUOTE]Originally posted by 1FaastC10
[B]
Yes, I agree as I noticed other discrepancies while reading through chuckscchevytrucks.
